Hidden Fuse? - Fiberglass RV
Old 04-23-2019, 09:07 PM   #1
Trailer: Bigfoot B17
Hidden Fuse?
1989 B17 Bigfoot. Several items not working ( Propane alarm,outside entry light,outside Hitchlight,and Refrigerator. Is there a "Hidden" fuse? I am hooked up to Battery,propane and 110. I found a blown 30 amp coming off the battery plus I checked the 4 convertor fuses. Where should I look next?
pter is offline   Reply With Quote
Old 04-23-2019, 11:35 PM   #2
Check the grounding. If they have a common ground and it is not making a good connection for conductivity that could cause this issue
Old 04-24-2019, 01:36 AM   #3
I have a fuse in a single fuse holder under the left dinette seat. It is in the wiring harness at the front bulkhead. It is a glass 30A fuse. Is that the fuse you found? I've seen this exact set up on several 17 Bigfoot trailers.
Old 04-24-2019, 07:50 AM   #4
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Yes, my Bigfoot has that fuse too. Driver side, under dinette seat against the very front of the camper. That could be the problem.
Old 04-24-2019, 03:29 PM   #5
Part 2
No fuses buT the convertor is making funny clicking sounds and the 15 a fuse doesn't wasn't to stay imbedded. When I pull a fuse ie furnace , from the convertor it is awfully hot....
Old 04-25-2019, 07:54 AM   #6
Sounds like a poor ground is the place to start...thanks !,,
AC installation (hidden) ericw Modifications, Alterations and Updates 85 07-26-2015 11:49 AM
found a hidden treasure in my uhaul frame andrew78 General Chat 4 12-04-2012 09:11 PM
Scamp 13, hidden spaces? Ron in BC Problem Solving | Owners Helping Owners 3 02-24-2012 12:39 PM
