High Quality Smoke Detector for TT? - Fiberglass RV
Old 05-17-2011, 09:37 AM   #1
Trailer: None yet.
Our 2007 21' Bigfoot came with a Kiddie smoke detector and since it was mounted about 4' from the stove, it goes off all of the time (toast in the morning can set it off). Can anyone recommend a good replacement smoke detector (we already have two CO2 ones)?
I thought of switching to a photoelectric one since it appears to be less sensitive to smoke from everyday cooking. Or maybe moving the smoke detector to the rear corner of the bedroom (~10' from the stove + ~5-6' from the shower). Any thoughts on either of these options?
Thank you for your help!
Esther
Trusty2010 is offline   Reply With Quote
Old 05-18-2011, 06:30 AM   #2
Trailer: 13 ft Scamp
I have no preference for brand or type, and have found all I have had work the same regardless. Detectors need to be mounted according to manufacturer directions -- usually so many inches from the ceiling, heat sources, drafts, etc. -- otherwise you will get false alarms or not detect actual danger. You should have received a Kiddie pamphlet with your other Bigfoot documents; or you can Google for the info.
Darnelle is offline   Reply With Quote
What Smoke Detector? curtis c Problem Solving | Owners Helping Owners 11 04-09-2009 01:52 PM
Scamp quality Russ V. General Chat 16 03-31-2008 06:00 PM
CO/gas monitor questions also smoke detector Q. Bobbie Mayer Problem Solving | Owners Helping Owners 14 12-01-2007 06:04 PM
Best Quality Michael Herbert General Chat 40 04-29-2007 10:40 AM
Propane detector and Carbon Monoxide detector. Yves Pelchat Problem Solving | Owners Helping Owners 6 02-05-2006 10:28 PM
