Hinge for bunk - Fiberglass RV
Old 07-25-2013, 05:41 PM   #1
courtney's Avatar
Trailer: 1982 13ft Scamp purchased on May 2nd
Hinge for bunk
I don't have the hinges that attach to the bunk for my scamp. Do I have to order them, or can I make do with something from the local box store?
courtney is offline   Reply With Quote
Old 07-25-2013, 07:09 PM   #2
Saskatchewan
The upper bunk base in both our Ventura and Trillium used what my menfolk call piano hinge. They use it for hingeing things that have to be safe and strong - from the local lumber yard.
Hazel in Sk is offline   Reply With Quote
Old 07-25-2013, 07:45 PM   #3
Figures, the only picture missing on the new Scamp website is the one for the bunk.. it's called a Chest Hinge. Since Scamp doesn't manufacture the hinge, I'm thinking you can get it just about anywhere this type of hardware is sold.
In the case of my Scamp and the hinge, it's not a piano hinge. I don't have a picture and am lousy at describing something. Sorry.
I found a picture!
Old 07-25-2013, 11:47 PM   #4
Roy in TO's Avatar
Here is one attached to a Scamp
The boler hinge is similar, more pics show various angles in this thread.
Biker bunk mounting pics?
Old 07-26-2013, 07:19 AM   #5
courtney's Avatar
Okay so these are on the Home Depot website, but neither them nor Lowe's has it in stock :-/
Can I use a piano hinge in it's place?
Wanting to use it this wkd, so would like to find a sol'n ASAP
Old 07-26-2013, 08:30 AM   #6
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
i would go with something heavy duty. since its a bunk bed.
the piano hinges i've seen so far where pretty flimsy.
just go to a good hardware store you should find something.
tartosuc is offline   Reply With Quote
Old 07-26-2013, 09:17 AM   #7
courtney's Avatar
When the couch is conveyed to the bunk bed configuration, is the rear part of the top bunk resting on and supported by the ledge or is it supported by the hinge itself?
Old 07-26-2013, 11:22 AM   #8
David Tilston's Avatar
In a Trillium the bunk rests on the piano hinge which is screwed into the plywood window frame.
Old 07-26-2013, 06:43 PM   #9
Saskatchewan
Checked with my hubby and he repeated - it is known locally as piano hinge. It comes in a variety of widths and weights so you need to choose something that will be strong enough.
Old 07-26-2013, 06:52 PM   #10
carlkeigley's Avatar
NE Oklahoma
piano hinge
Google Image Result for http://www.eia-rackmount-case.com/case-hardware/336-0.060%20Aluminum%20Piano%20Hinge.jpg
Old 07-26-2013, 07:15 PM   #11
Ed Harris's Avatar
You should be able to find a Piano hinge in many different sizes and strengths at any real hardware store.
Lowes and H.D. even sell SS ones that should be plenty strong enough for the bunk.
They also sell the hinge shown in the Scamp pic in the cabinet hardware section in little bins in both stores.
If you are in a bigger city they also will be found at a Rockler or Woodcraft store if there is one?
Old 07-26-2013, 08:03 PM   #12
Do not confuse the needs of a Trillium or Scamp or some other brand for bunk supports. There's a reason each use some thing different. For instance, as Dave mentioned
the Scamp bunk is screwed to the bottom of the piece that is fiberglassed to the front wall of the trailer, NOT the window frame. So, the type of hinge is different based on how it works when it's NOT in bunk bed mode, but gaucho mode.
Hence, the hinge is NOT a piano hinge for a Scamp, but a chest hinge like the image I posted and the picture Roy posted.
Old 07-27-2013, 05:52 AM   #13
Ed Harris's Avatar
I am with Donna on this one for sure. Although there may be a way to use a different hinge than the factory I was just saying that many more hinges are available in a Hardware store than you will find in the 1st place you see hinges there.
For some reason I can think of 3 different places I get hinges all the time in the same store?
Old 07-27-2013, 11:18 AM   #14
courtney's Avatar
Ended up using a piano hinge. Also made a rail for the top bunk:
CT-13 Main Bunk bed hinge dimensions djtriceflt Problem Solving | Owners Helping Owners 20 11-09-2011 07:49 AM
Bunk Hinge Placement on 1977 Boler Amy W Problem Solving | Owners Helping Owners 3 08-03-2010 09:29 PM
Bunk hinge shelf/ledge thingy Valerie G Problem Solving | Owners Helping Owners 8 07-12-2007 08:54 PM
Table and Hinge Graeme Problem Solving | Owners Helping Owners 15 07-12-2007 12:36 PM
hinge help Legacy Posts Problem Solving | Owners Helping Owners 2 04-12-2003 06:37 PM
