Hi: All... Her's a pic of the
Boler door after I drilled out the hinge screws. I filled the holes with Tech Steel avail at auto supply stores hardens in about 1hr. file flat and center the door in the opening with th hinges attached to the body so you can mark the new holes for the door. I used
Scamp hardware to attach the door. Bolts and acorn nuts.
