hitch problem - Fiberglass RV
Old 03-09-2003, 11:12 AM   #1
hitch problem
I've noticed the last couple of times I've pulled the Casita what appears to be sloppiness between the coupler and ball. When I initially pull forward or come to a stop there is a feeling of front or backward movement. I've never felt this in a trailer before. I've tried tightening the coupler and then backing off a quarter to half a turn but it doesn't seem to help. The hookup seems secure. When I lower the tongue jack to unhook the Casita from my truck, I usually have to jump up on the step bumper and give a bounce or two for the coupler to pop off the ball. Any suggestions would be much appreciated...
Rich
Old 03-09-2003, 12:09 PM   #2
hitch problem
You may have bent something in the hitch. I would replace the internal parts. A repair kit is available for your Shelby 5101 coupler at www.etrailer.com. $10.25 for safety is a small price to pay.
http://www.etrailer.com/Merchant2/merchant...tegory_Code=crk
Old 03-09-2003, 12:50 PM   #3
Hi Rich ... sorry you're having some problems!
Couple of thoughts:
1. Is the ball itself loose? It can look tight, but still be loose enough to wobble when the trailer is attached.
2. I know you've done a lot of trailering ... has the draw bar pin (which holds the draw bar in the vehicle hitch) worn ... and is allowing a little play in the draw bar?
3. Are you sure your trailer brakes are working as well as they did? It could be you are feeling a dragging shoe ... or a worn pad, giving you a different sensation than before.
4. Have you been emptying too many water-insertion-device containers?:)
Old 03-09-2003, 07:20 PM   #4
Rich,
Every class III hitch I have ever had has had some play in it. When you take off or slow down you will feel it. If your window is down you will hear it. That is one of the reasons that I use a WDH that applies tension on the joint.
The problem getting the coupler off of the ball is a simple adjustment. When you are hooked up lay down and look up under the coupler. You will see a nut. Loosen it up 1/8 turn and then try to unhitch it. You may have to do it a couple of times. It should be kept as tight as possible and still easily come off.
It is possible that you have a problem as Charles has indicated and I would check them. Also you will see the clamp just above the nut that holds the coupler on the ball when you loosen it. Check it when not connected for unusual wear. If you grease the ball when you tow it should be OK. It could be wore out but I doubt it. I have pulled trailers thousands of miles and have never replaced one because of wear.
Last be sure you have plenty of hitch weight and not loaded to heavy aft.
You no doubt have checked most of these things but we have tried to cover everything. Sometimes we all miss the simplest of them.
Good Luck
Old 03-10-2003, 11:10 AM   #5
The forward/backward movement of the coupler on the ball is something I started noticing in the last few months, it wasn't apparent during my first year of towing the Casita. I've ruled out loose ball and worn drawbar pin. I do need to get the Casita down to a scale, but we're not carrying anything more or loaded differently than we did during our first year, so I don't think tongue weight or weight distribution is the problem. When I replaced the Carlisles with Goodyear, the brakes seemed OK, so I don't think that's a problem. I might look into the brake controller though, since I haven't adjusted it since day one. There is some up/down and side to side play in the drawbar but no forward/back, so I don't think the problem lies with
the drawbar or reciever. It's troublesome, but I will get to the bottom of it. At some point I guess I'll have to get down on the ground and look up into the coupler to make sure everything's OK. My bones and joints aren't looking foward to that...
Rich
Old 03-10-2003, 11:56 AM   #6
movement
Rich, when we got our 2002 SD last April I had the same problem, since it was delivered to us from Rice it had over 2000 miles on it .
I adjusted the brakes ( did it myself ) and fine tune the Tekonsha Voyager brake controler and that took care of the problem.
I now have over 5,000 miles on the trailer and it still works great.
I traded for a bigger Dakota and it came with a brake controler on it
(don't remember the brand) and it was junk, graby brakes so I had
my old Tekonsha controler and put it on and everything was great
smooth stoping. Try adjusting your brakes and find tune you controler and if that don't help you may need a new brake controler.
I hope this helps and keep us posted on how thing go. Jay
Old 03-10-2003, 11:05 PM   #7
the ball
I towed my Scamp for 3600 miles with an annoying slack and slop. When I got home, to my chagrin (that's French for doofis) I had a 1 7/8 ball on! Everybody knows Scamp uses 2" diameter. My excuse is I have other trailers that use 1 7/8. Check the ball.
Old 03-11-2003, 04:32 PM   #8
Orginally posted by e. s. munson
Oh, one of those, :bh Glad you didn't have a problem, now you have a story to tell your TT buddies.:lol
Old 03-11-2003, 06:09 PM   #9
coupler adjustment
One way to check the (Atwood) coupler adjustment is to:
1. Hook up the trailer, latch the coupler (on level ground, wheels chocked).
2. Crank the tongue jack from 'off the ground' to where it begins to contact the ground, while watching the coupler/hitch ball. Need to crank it until the tongue weight is off the tow vehicle, a couple of inches.Then, if the trailer coupler begins to raise the hitch on the car with no slop, it's OK. If the coupler raises without immediately pulling the hitch with it, it needs adjusting.
This takes out the forward and back slop between the coupler and ball.
3. No need to crawl under to look at the coupler parts. A small mirror will show the adjustment nut. Need a 3/4" deep socket, tighten it (counter-clockwise, looking down), retest, unhook, and you're done. The nut is an elastic lock nut so it'll offer a little resistance even if the coupler is out of adjustment. :)
Old 03-11-2003, 08:54 PM   #10
I second "check the ball" also; easy to have the wrong one (been there, done that!).
Also, if the tongue weight is too light, a trailer will make a LOT of noise when it is tugged around.
Pete and Rats
Old 03-11-2003, 09:01 PM   #11
Don,
I don't think he is going to find the coupler nut too loose. Because he has said that he has to jump on the bumper to get it to release from the ball when unhitching. I think he is going to find the cause of the jerking in another place. But that is a good ideal that you have to use a mirror.
What have you found Rich? You have us all worried!
Have you adjusted the power setting on the right side of your brake control yet?
Have you found a good level spot to park on a paved lot so you can observe movement while trying to rock the trailer forward and backward? You should be able to see where the play is. Remember it probably won't be very much.
Good luck
Old 03-11-2003, 10:01 PM   #12
Orginally posted by Ron and Bernice
Not to worry, I'm looking into it. I've ruled out the two most obvious possibilities. The Casita factory supplied the 2" ball and I verified long ago it is, indeed, a 2" ball. And, I've fine tuned the coupler/latch adjustments to the point there's slight resistance with both hitch and un-hitch. I've cranked the tongue jack down with the coupler latch locked in place and the back of my pickup raises as I crank without the coupler popping off the ball; so, I'm not TOO worried about the trailer coming un-hitched...though such thoughts are always in the back of the mind once you've seen such a thing happen, and I have. I will figure it out; and, when I do, I'll post my observations and conclusions for all to consider with regard to their own trailers.
Rich
Old 03-12-2003, 06:45 AM   #13
Are you sure it's the coupler and ball? The hitch on our old van was terribly noisy, can't remember the make though. The draw bar was a tiny bit sloppy and the clanks and jerks it made were incredible.
The current van has a different make of hitch, possibly U-haul and the draw bar fits very snug. Often has to be hammered out if we forget about it for a few weeks. This one does not make a sound and no jerks.
Maybe the draw bar is your problem.
Nancy
Old 03-14-2003, 09:53 AM   #14
Orginally posted by Nancy D
That's one possibility I haven't eliminated. There is some up 'n down and side to side sloppiness with the hitch but no forward/back, which is what I feel. The movement I feel is kinda like a "nudge" from the Casita when coming to a stop and, to a lesser extent, a slight jerk when initially starting to pull. However, this is not something I felt at any time during the first year and 7500 miles towing the Casita...well, except for the time at Moraine Park when I forgot to lock down the coupler latch. Fortunately we were just towing over to the dump and didn't get too far down the road with the latch not locked down. I've got another draw bar I could try, but it isn't one I'd want to continue using. I hate the thought of having to suffer the expence of replacing the current class III on the truck since I plan on buying a new truck in the not to far off future.
Rich
Old 03-14-2003, 10:14 AM   #15
Whoa. Rich. Now you have me concerned. Are you talking about movement in the hitch itself (the hitch + receiver) bolted to your car? There should be absolutely no movement in that.
If it moves, you either have a loose bolt or a broken weld. Some hitches are one-piece. Others come in pieces and you have to assemble prior to bolting onto your car.
But if everything is tight ... nothing should be moving.
>>I have another drawbar
By drawbar, you mean another ball-mount, the piece onto which you mount the ball, right?
Or are you talking about when the ball-mount is pinned the hitch, you can wiggle it around a bit (that's normal) ... and as I said before, check for wear on the pin and the pin holes.
Old 03-14-2003, 10:38 AM   #16
quote:
>> I might look into the brake controller though, since I haven't adjusted it since day one. <<
Yikes! If you never adjusted your controller, I think this is where your problem is.
The fix could be as simple as re-adjusting the controller, or maybe there is a serious problem with the brakes now (worn out) because the controller has been out of adjustment for so long.
Depending on the controller model, most should be adjusted on every hook-up.
Also, check brake current on both sides. Maybe one side is not braking, giving a pushing sensation.
Old 03-14-2003, 01:48 PM   #17
Orginally posted by Charles Watts
Whoa. Rich. Now you have me concerned. ...
Not to worry, Charles, the hitch to truck frame connection is solid, only the drawbar moves. There's maybe a 1/16 to 1/8 inch of play in all directions. I've checked the pin and pinholes and don't think there's a problem with either. I bought the truck from my son. He used it to put his boat into and out of saltwater and frequently left the bar in the receiver, causing lot's of saltwater corrosion. Before he sold the truck to me, he had to take a sledge hammer to knock the bar loose and I had to take hammer, chisle and coarse rasp to clean out the rust before I could get MY bar into the receiver. I'm thinking maybe 8000 miles later, more layers of rust have rubbed away over time and the fit between the bar and receiver is looser than it should be. If that's the case, the only remedy I see would be a whole new hitch, an expense I don't want to suffer as I'm planning on buying a new truck before too long.
Rich
Old 03-15-2003, 01:47 PM   #18
Rich, if loose fit is the case, and you don't know anyone who welds or brazes, then you might try some brass or steel shim stock from a hardware store, just contact-cemented to the bar.
No doubt it will wear out and pull loose occasionally, but it would be a darn sight less expensive than a new receiver!
Or make some skinny wedges and drive 'em in and forget about pulling out the bar for the season.
Pete and Rats
PS Folks who live in the land of snow should be in the habit of removing your bar occasionally so it won't get frozen in by corrosion. My brother lives in Vermont and had to remove the receiver and put in in a press at work to bust the bar loose -- almost exceeded the 40 ton capacity of the press!
Old 03-15-2003, 07:19 PM   #19
Removing hitch from receiver
I guess all of you are more agile than I am. I remove mine right after I unhitch and throw it in my tow vehicle. Why? Cuz, I guarnatee you it will be less than 5 minutes before I whack my shin on it if I don't......Aren't bifocals grand....NOT!;)
Old 03-15-2003, 07:59 PM   #20
Suz
I do same thing.Remove after I unhook.:wave
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
RAV4 and equalizer hitch - any problem? Glenn Baglo Towing, Hitching, Axles and Running Gear 6 10-31-2008 02:49 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 04:05 PM
Problem Name Joanie Jokes, Stories & Tall Tales 1 02-26-2007 04:38 PM
