Hold down clips - Fiberglass RV
Old 06-19-2011, 05:21 PM   #1
Trailer: '74 Trillium 1300
Hold down clips
I have a feeling that my Trill '74 had hold down clips for the spiders on the stove.
Does anyone have a picture or description of these beasts? I don't even know how they would have fitted.
These forums are an unbelievable resource!
IanWR is offline   Reply With Quote
Old 06-20-2011, 09:22 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Meridian R/V in Poco has'm. I think they come in one or two different lengths..
Old 06-20-2011, 10:16 PM   #3
Cool
Spider? I call them grates...
The clips are just V-shapes with a jog in one leg that goes into the tiny hole in the stovetop. My stove has 2 clips for each grate.
Top one is installed holding the grate secure.
Bottom one is removed to show the clip itself.
Old 06-21-2011, 07:40 AM   #4
Trailer: 2015 Escape
My grandparents (born in the 1870s) called frying pans 'spiders'.
Old 06-21-2011, 10:09 PM   #5
Yo are correct that meridian R/V has them - I found them today.
Sadly they cost with tax almost $25.00 for the pair, so maybe I will continue to wrap the grates in a towel and put them in the sink!
I'll see if I can make something that will do the job.
Cheers
Old 06-22-2011, 09:30 PM   #6
I remember pre-hack someone made the clips out of paperclips! Shoot, it would be worth trying....
Old 06-23-2011, 09:27 PM   #7
KevinWA's Avatar
Trailer: Trillium 4500 1978
wow..i droped 2 down into the abyss of the stove.....wanting to remove stove and find them...then clean up the stove a bit...it has been painted in the past...any tips on how to remove the stove?..i am willing to bet the fridge will need to come out first.
KevinWA is offline   Reply With Quote
Old 06-24-2011, 03:37 AM   #8
james kent's Avatar
Trailer: Boler 1984
My stove has two screws through the top that when removed lets you remove the top and get full access to the burners. If I remember right, I think that the lower pan can now be unscrewed from the counter top.
Old 06-24-2011, 11:44 AM   #9
If it is a Trillium like mine there is a hidden clip on each side. Put something thin under the lip of the stove in the middle of the side and pry the stove top up. Mine was corroded under, so took some force - be careful not to bend the stove top.
With the top removed the pan is held in by 4 tiny screws but you have to disconnect and remove the burners first.
Cheers
Old 06-28-2011, 02:39 PM   #10
Kevin Poll's Avatar
Trailer: 1975 Trillium 13 ft / 2002 Honda Odyssey
here are some photos of the clips in question from a Brown stove in a Trillium 1300. the metal is quite thin and a bit springy, My opinion is that it would be fairly easy to bend something similar that would work using basic tools (tin snips and needle nose pliers).
Kevin Poll is offline   Reply With Quote
Old 06-28-2011, 11:12 PM   #11
Thanks for going to so much trouble.
It certainly looks as if I could bend something up.
Thanks again
Cheers
Old 06-29-2011, 11:01 AM   #12
Doug Mager's Avatar
These look like the same clips which came with our stove in our Trillium.
Using Gutter Clips for Patio/Awning Lights Donna D. Modifications, Alterations and Updates 10 04-09-2015 09:28 PM
Is this a Burro RV in these movie clips? bill&sandra General Chat 8 04-03-2010 10:38 AM
Stove eye retainer clips WTB?? Randy Bishop Problem Solving | Owners Helping Owners 6 10-26-2009 12:24 PM
Questions about Clips around the interior / exterior windows John Truitt Care and Feeding of Molded Fiberglass Trailers 4 02-23-2009 01:14 PM
1980's era Bigfoot curtain clips? V'sGlassSleeper Classified Archives 4 09-18-2007 10:52 AM
