holding tank leak - Fiberglass RV
Old 07-23-2006, 04:12 PM   #1
Karalyn's Avatar
Trailer: Casita 2000 Spirit Deluxe
A rock hit the bottom of the plastic holding tank and caused a leak in my son's camper. Just wondering if anyone has an idea on how to repair a plastic tank with a crack in it??
Karalyn
http://karalynsmaltese.com/</B>
Money will buy a fine dog, but only kindness will make him wag his tail.
Karalyn is offline   Reply With Quote
Old 07-23-2006, 04:24 PM   #2
Chester Taje's Avatar
I had a crack in my water tank on a different unit.I used liquid plastic in a tube.Worked great.
I should add that i did it too a fresh water tank----40 gals
Old 07-24-2006, 01:06 PM   #3
Brian B-P's Avatar
This came up previously, and here's a link to my description of my repair: Leaking Grey Water Tank on Boler. A follow-up with a photo is a couple of posts later in the same thread. The patch is holding up fine, a couple of camping weeks and a few thousand road kilometres later.
Old 02-24-2013, 03:30 PM   #4
Trailer: 17ft. Burro
I have used Gorilla tape to repair the graywater holding tank on our Burro. I think that the tank is made of ABS, but I think that the Gorilla tape will work on most anything. Just make sure the area around the crack is quite clean and then apply a couple of layers of Gorilla tape. This tape should be readily available at home centers, paint stores, and hardware store.
Landy is offline   Reply With Quote
Old 02-24-2013, 04:51 PM   #5
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
Look for a shop that can do plastic welding. There are other solutions, but welding the crack is the best.
Old 02-24-2013, 05:09 PM   #6
Trailer: 1975 Boler
I had a golf ball sized gash in my holding tank. I cut a piece from an old plastic cutting board that was the same plastic, and then spent some time *slowly* heating each up around the edges and then 'welded' them by smearing the soft plastic with a heated up knife. It hasn't leaked in over 2 years.
Evan Friesen is offline   Reply With Quote
Old 02-24-2013, 05:42 PM   #7
Steve Hammel's Avatar
Trailer: Trillium 4500
A good old fashioned soldering iron works great. Make sure it is dry first.
Steve Hammel is offline   Reply With Quote
Portable Holding Tank R&SGove Problem Solving | Owners Helping Owners 2 06-18-2008 08:58 AM
Holding Tank Chemicals Pete Dumbleton Problem Solving | Owners Helping Owners 10 01-17-2008 06:42 PM
New Holding Tank Vent Cap Frederick L. Simson Modifications, Alterations and Updates 9 10-01-2007 07:38 PM
holding Tank Oders Legacy Posts Modifications, Alterations and Updates 10 07-21-2003 04:17 AM
holding tank antifreeze? Legacy Posts Problem Solving | Owners Helping Owners 6 02-17-2003 11:43 AM
