Old 07-27-2011, 05:46 AM   #1
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Holding tank odor control.
We have used Bleach in our Black water holding tank to control odors.
However: This might be a really bad idea !
A tip from Sharon: Suggest that using Clorox or other types of bleach in a Porta Potty or Camper toilet's holding tanks, for odor control, could result in harmful vapors when mixed with Urine.
A tip from Darnelle says "Mr. Clean" works really well.
Of course the Blue Stuff works too, but is kind of expensive.
What are you folks using?
Kip
Kip in Ga. is offline   Reply With Quote
Old 07-27-2011, 06:15 AM   #2
Alf S.'s Avatar
Trailer: 2007 19.5 ft Escape 5.0 / 2010 Nissan Frontier (1973 Boler project)
Hi: Kip in Ga. ...We use "The Geo Method" for RV's,( Google search required) for both grey water and black water tanks. It's just laundry products so it's environmentally safe for septic systems. Calgon+ your fav. laundry detergent+ bleach. We've found we can't use fragrance free stuff as then you still get odours!!! Make sure that all your drain line traps are full of water too!!! Our shower has a shallow V trap rather than a P trap and seems to empty itself while towing. Our grey water smells worse at times than the black water. Probably food bits from washing dishes!!!
Old 07-27-2011, 07:13 AM   #3
Alf,
Any chance you can put a plug in your shower drain to keep the fumes in the tank ?
Bill K
Old 07-27-2011, 07:30 AM   #4
Kip in Ga.'s Avatar
We don't wash dishes, we throw the paper and plastic products away. The only glass stuff we take is coffee cups.
Ann wipes out the "Tefflon Coated" frying pan with a wet then a dry paper towel. Then a quick soapy wash in the sink. A trick she learned from all those cooking shows she watches. So in reality there are no solids going into our gray tank, only hand washing dirt and soap.
Kip
Old 07-27-2011, 08:40 AM   #5
Kip
Here is a product that does what it claims, cheaply, safely, responsibly and effectively....
OD-410 ODORLOS HOLDING TANK TREATMENT
We buy the 5qt jug and then refill the small dispenser jug, seven years and we are still on our second jug. With the small Scamp holding tank, it can be used generously without using much.
Another point... frequent rinsing and cleaning of the hot water tank may be just as important for odor control as the holding tanks,plus if you have air conditioning, it is wise run it in a closed trailer for a couple hours unoccupied before storage, it acts as a dehumidifier and a thoroughly dry trailer is less likely to produce odors.
Removal of odor causing items between trips can help as well, since coffee, laundry soap,snacks, tobacco etc. may smell good individually,they may not play well together locked in a closed trailer.
Gym shoes, damp jackets, tobacco smoke, and pet supplies are also smells to which you can become used to, but which others may notice and find offensive in such a closed space. Changing bedding ,removing laundry and vacuuming inside may also help.
Running a little fresh water down the drains can help as well.
Room freshners, like glade,febreze, or fresh flowers can help but like the "frictionsway" issue, they can only be truly effective when the trailer is clean and odor free to before using them.
Even with a clean and pleasant trailer,the screen door and fantastic fan can bring the oudoors in and help a lot when guests arrive. Four people in a scamp 13 is not the same as four people in a house.
Old 07-27-2011, 08:46 AM   #6
honda03842's Avatar
Name: Norm and Ginny
New Hampshire
Last year we took apart a trailer and the residuals in the gray tank were interesting. Though no apparant solids go in, solids seem to be created from the liquids, grease and the like.
I agree that a gray tank can be more foul smelling than a black. After dumping I always add a little water to the tanks so our journey can loosen and capture what remains. On occasion I have added a little bit of Dawn to the grey tank with the water.
On occasion I'll add a lot of water and as we travel let the water work it's magic, dumping upon arrival at the destination.
We of course close all traps while driving. This helps keep water in the trap creating some measure of vacuum, reducing the possibility of a trap draining.
Norm
Old 07-27-2011, 11:10 AM   #7
cpaharley2008's Avatar
Trailer: 2012 Escape 19' with Ram Hemi or FJ Cruiser
Calgon water softener in powder form, works for me.
Old 07-27-2011, 12:24 PM   #8
Trailer: Fiber Stream
Cool Bacterial Agent
Phred's Poop Sheets
Originally Posted by Phred's Poop Sheets
Active BACTERIA will do the job. A properly set up and maintained system won't need much either. As opposed to chemicals (where more and more must be used with less and less effect), when adding bacteria "less is better." It's important that you follow the instructions. You must start with a clean tank (or residual chemicals will defeat the action). You need to start the tank with a few gallons of water. You shouldn't add the bacteria until there's a deposit of human waste in there. If you do it right, it will take about three, in normal use, dumps before you have a good, renewable system. You can then keep it going with only small additions of bacteria every other dump or even fewer.
WHICH BACTERIAL AGENTS ARE THE BEST? There are several good ones. Homeowner septic tank chemicals work. They're readily available in most supermarkets and cheap. They are not fast working, which is why RVers are sometimes dissatisfied with them, but they were designed for thousands of gallons and a lot of time, not the short time demanded by the 40-100 gallons in most RVs. "Rid-X" is the best of these.
I use "Rid-X"
Old 07-27-2011, 01:00 PM   #9
Originally Posted by Frederick L. Simson View Post
Phred's Poop Sheets
I use "Rid-X"
If the dumpstation goes into a septic field then you are probably doing them a favor using Rid-X, but the enzymes in Rid-X are designed to feed and maintain healthy levels of digestive bacteria in your septic system.
Unlike Septic tanks, RV holding tanks are flushed regularly and so you need something designed for that purpose like Odorlos or it's equvalent.
Old 07-28-2011, 05:25 AM   #10
Kip in Ga.'s Avatar
When you folks use the blue stuff, Odorlos, or the like, how much do you put in the camper black tank?
Directions say to use 4 oz. AND that will treat up to 40 gallons.
The 4 oz seems excessive for smaller tanks such as our 15 gallon ones and Porta-Potties.
Kip
Old 07-28-2011, 05:47 AM   #11
just use a tablespoon....that's what I do, but remember to clean it(the spoon) before using again
Old 07-28-2011, 06:28 AM   #12
Kip in Ga.'s Avatar
Do ya just drop the spoon in the tank and catch it when dumpin the tank?
Sorry, couldn't help myself!
Thanks for the info!
Kip
Old 07-28-2011, 09:04 AM   #13
jen b's Avatar
Trailer: 1980 13 ft. burro
I only have a 5 gallon jug sitting alongside my Burro as my gray tank, but so far so good on the odors. I use Dr. Bronner's castile peppermint soap for dish cleanup (would rather do dishes than create trash) and my little graywater jug smells pleasantly minty.
jen b is offline   Reply With Quote
Old 07-28-2011, 09:33 AM   #14
Cool
... the enzymes in Rid-X are designed to feed and maintain healthy levels of digestive bacteria in your septic system.
Unlike Septic tanks, RV holding tanks are flushed regularly ...
When I am not out camping, the Fiber Stream is now in constant use as a guest house in the back yard. I only empty the black tank when it's full.
holding tank leak Karalyn Problem Solving -- Owners Helping Owners 6 02-24-2013 04:42 PM
Portable Holding Tank R&SGove Problem Solving -- Owners Helping Owners 2 06-18-2008 08:58 AM
Holding Tank Chemicals Pete Dumbleton Problem Solving -- Owners Helping Owners 10 01-17-2008 05:42 PM
holding Tank Oders Legacy Posts Modifications, Alterations and Updates 10 07-21-2003 04:17 AM
holding tank antifreeze? Legacy Posts Problem Solving -- Owners Helping Owners 6 02-17-2003 10:43 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
