hole in grey water tank - Fiberglass RV
Old 09-05-2008, 01:54 PM   #1
Joseph and Melanie Castine's Avatar
Trailer: Casita 17 ft Spirit Deluxe sold it 2011
Question
On way back to Upstate NY from NJ on PA Turnpike or Rt 81 or 88 a piece of angle iron flew up and stabbed my tank. Hole/gash about 4 inches.
Any ideas on repair????
Joe and Mel
Joseph and Melanie Castine is offline   Reply With Quote
Old 09-05-2008, 04:08 PM   #2
Trailer: Fiber Stream
Talking
I suspect that you'll first have to "drop" the tank; uninstall it from the trailer.
I looked through the Helpful-Links under Resources in the Document Center at the right and found:
Plastic Welders and Repair Kits
Good Luck!
Old 09-05-2008, 04:13 PM   #3
A bunch of PC7. (At Lowes, Home Depot)
It is the 2-part epoxy paste that you mix like play dough.
I would clean the area with rubbing alcohol then when it is dry I would make sure the PC7 is in the hole and a liberal amount around the hole on the outside then To insure it sticks and stays put I would screw an aluminum (Flashing) over the top of it.
It takes all night for this stuff to get hard.
Old 09-05-2008, 04:16 PM   #4
Gina D.'s Avatar
West Coast USA
oops.
Coulda been worse..
coulda been a full black tank!
(yech)
Old 09-05-2008, 10:27 PM   #5
Pete Dumbleton's Avatar
You might also check the cost of a new tank.
Old 09-11-2008, 12:02 PM   #6
Post
Finally found tank repair kit at RV service in Binghamton. Just liked the one recommended in Frederick's link. Used two of them, crossed fiberglass tape. Looks great. Will let you know if it leaks.
Joe and Mel
Black water-Grey Water ROIDON L Plumbing | Systems and Fixtures 3 07-23-2009 06:09 PM
Grey water overflow hose Fran L Problem Solving | Owners Helping Owners 3 07-06-2009 09:22 AM
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 7 09-01-2007 10:12 AM
Grey Water Tote Brenda Novakovski General Chat 12 08-07-2007 08:48 AM
