Hole in roof where solar wire enters body - Fiberglass RV
Old 07-27-2014, 02:25 PM   #1
I bought a 2014 Trillium from Great West Vans (dealer in Bay Area of Ca). Moved cross country to NY - first rain flooded inside of trailer. No help from dealer. Discovered hole the size of my pinky finger in roof where solar wire feeds in. Wire has flimsy plastic sheath around it - hole is a bare hole that just looks drilled into the fiberglass. (In a water run-off trough no less)! Obviously they forgot to add something and overall seems like poor planning. I am wondering how to fix this. Can I seal with Dicor around the wire?
Kbreeding is offline   Reply With Quote
Old 07-27-2014, 05:02 PM   #2
honda03842's Avatar
Name: Norm and Ginny
Cap it with a thru hull boat fitting. I'll post what I used. We have used this for 3 years without issue, I painted the cap white before installing to protect it from UV.
The Lexan makes a great seal.
Thru Shell Fitting
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-27-2014, 08:05 PM   #3
I would at least use a rubber grommet with some type of sealer, I like the Proflex. Our Uhaul had a grommet where the solar wire came through and never leaked. I have a coffee can full of grommets, although try and find the right size!!
Old 07-28-2014, 05:55 PM   #4
Thank you so much! I will be working on this this week
Old 07-28-2014, 06:58 PM   #5
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
While this may not be the same manufacturer, this is what Escape uses for their solar feed throughs as well as for the wire from my outside cell antenna. They use Dicor between the fitting & the trailer as well as a filler around the wire.
Old 07-28-2014, 08:17 PM   #6
deryk's Avatar
New Jersey
Kara, this is what I used while installing the wires through my roof for my solar panel My ParkLiner has got Solar! I got it from a local boating store. I'm pretty confident it wont leak for a long time since its designed for marine installations.
deryk
solar
BIG HOLE IN ROOF ( Boler ) trailerlust Problem Solving | Owners Helping Owners 17 04-07-2013 07:54 PM
yellow wire/brown wire deryk Electrical | Charging, Systems, Solar and Generators 24 01-01-2013 06:34 PM
Mounting things on roof w/o drilling a hole stev Modifications, Alterations and Updates 26 10-21-2012 01:59 PM
Large hole in roof trailerlust Problem Solving | Owners Helping Owners 15 12-15-2011 09:29 PM
Burro enters solar system rabbit Modifications, Alterations and Updates 4 07-04-2011 05:49 AM
