hood for 2 burner stove - Fiberglass RV
Old 03-19-2009, 11:18 AM   #1
Cyndivg11's Avatar
Trailer: 1984 FiberStream
I'm looking to add a hood above the 2 burner stove- but I only have 4 inches from the bottom of the fiberglass shelves to the window.
Anyone know of anything that would fit? It can be 20" long across.
78' trillium
Cyndi
Cyndivg11 is offline   Reply With Quote
Old 03-19-2009, 12:05 PM   #2
The Hobo's Avatar
Trailer: 1976 Triple E Surfside
I just went to The Metal Supermarket,
and got a colored piece (I wanted Red)of Aluminum, and bent it myself to the shape I needed.
Then I airbrushed the Coca Cola name on the surface.
I put 2 hinges on it,
so it would flip upwards to the right(keeps it out of the way when your cooking).
Hope this helps.
1976 Surfside Tripple-E
The Hobo is offline   Reply With Quote
Old 03-19-2009, 06:47 PM   #3
Raya's Avatar
Gee, it's awfully hard to visualize.... (hint, hint )
(And I want to see a red aluminum Coca-Cola vent hood )
Raya
Old 03-19-2009, 06:58 PM   #4
ooooh, check out all the red diamond plate stuff!
On eBay Red Diamond Plate
Old 03-19-2009, 08:03 PM   #5
Raya's Avatar
Ooh, me likey!
(I wonder what makes it red (i.e. coating, or..?); I don't see where they say.)
Old 03-19-2009, 08:10 PM   #6
Hummm, don't know. I've purchased stuff from CutsMetal before. I see the diamond plate is not only in silver, but red (two tints), black, and blue (two tints). Totally cool.
Check out the garbage cans! Diamond Plate Trash Can
Old 03-19-2009, 11:20 PM   #7
David & Leslie's Avatar
Trailer: Scamp 16 ft Side Bath
Ooooooooo, Donna, thank you for that link to CutsMetal! We've been wanting to add a "backsplash" behind the cooktop & sink counter to protect the rodent fuzz on the wall. Thinking, thinking ... L 'n D
“Imagination is everything. It is the preview of life's coming attractions.” A. Einstein
David & Leslie is offline   Reply With Quote
Old 03-20-2009, 07:14 AM   #8
ERIC B.'s Avatar
Trailer: 1988 Perris Pacer 13 ft / 2005 Honda Element
Cyndi,
You might try a rectangular aluminum cake pan screwed upside down to your cabinet. One member here did that to their trailer (Casita I believe) and it looked great. It was painted to match the cabinets and blended in well.
Eric
ERIC B. is offline   Reply With Quote
Old 03-20-2009, 07:30 AM   #9
For backsplash material available from Home Depot or Lowes types places, check this topic:
Kitchen & Backsplash, 2 Kitch
For the cake pan idea Eric posted, I'll look for the topic and post the results later... gotta go to work!
Old 03-20-2009, 08:30 AM   #10
Trailer: 2008 Casita 17 SD
Hi Eric,
I think it may have been my range hood "mod" you're recalling. I didn't like the factory installed one. It just looked too big and clunky for this small of a galley area. I used a Wearever aluminum baking sheet (approx. 13" X 17"). I cut the back lip off so that it fit flush with the front face of the overhead cabinet, spray painted (primer and gloss white), drilled and riveted it in place, and sealed all the edges with white silicone sealant. I replaced the original vent fan (integral with the original range hood) with two 12 volt dc pancake computer fans. To wire the fans, I utilized the existing 12 volt wiring from the original light fixture of the original hood. The switch (right side of overhead cabinet) is just a simple on/off toggle switch. The fans work good and you can barely hear them when running. It really opened up the galley area considerably.
Old 03-20-2009, 09:01 AM   #11
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Greg Finke
That's the best one I've seen.
Old 03-20-2009, 10:38 AM   #12
peterh's Avatar
[quote]
Attachment 18610
Now that is cool. I love simple solutions that use readily available materials in innovative ways, and you're right, you don't actually need a "hood" to pull stove top smoke out, just an airflow pattern that pulls the smoke toward the exhaust, and your hood looks like it would do the trick. [on edit: Egads! That is the worst run-on sentence I've posted in a long, long time!]
Your design also gives me an idea on a solution that will work both for our kitchen and Cindi's, both of which have windows over the stove that reduce the wall space for a hood. I'll draw it up and post it later today.
Old 03-20-2009, 04:11 PM   #13
Thanks all for the kudos. I hope it works out well for you. It really was a pretty simple and straight-forward installation. By the way, I found that a composite cut-off wheel on my 3" air grinder worked really good for cutting the lip off the aluminum baking sheet. As to mounting the pancake fans, I used a chunk of that marine plastic sheet material (1/2" thick) that they sell under the name Starboard <sup>™</sup>. It's probably available at several places, but I bought it at West Marine. I drilled out two holes with a hole saw and mounted the fans inside the holes, (flush mounted,) as opposed to surface mounting them. I suppose either would work, but it just looked a little "cleaner" this way.
Greg
Old 03-20-2009, 06:36 PM   #14
thanks Greg! Great mod that many may find useful, I'm glad you were able to repost it
Old 03-21-2009, 03:38 PM   #15
Francis McDermott's Avatar
Trailer: Surfside 14
I hope Cyndi likes Greg's plan--I certainly do!
Could you describe the design of the outside exhaust/vent exit? I'd like to work out a low profile but weatherproof vent for two computer fans to a Surf Side that never had a stove vent.
Thank you
FM
Francis McDermott is offline   Reply With Quote
Old 03-22-2009, 07:20 AM   #16
Cyndivg11's Avatar
[quote]Hi Eric,
Attachment 18610
Yes! That's perfect! I probably have some leftover computer cases (with fans intact) I can use! AND the fans can't be more than 3 inches wide- works perfect! Very inventive!
Old 03-23-2009, 07:12 AM   #17
Here's a link to find the exterior vent for the exhaust setup.<a href="http://www.ventline.com/Prod.asp?ID=5&ProdID=51" target="_blank">
</a>
Old 03-23-2009, 08:04 PM   #18
Thanks heaps, Greg. That's not too hard to approximate. Incidentally, did you engineer your fan mounting centres or go by instinct?
Old 03-23-2009, 11:47 PM   #19
Thanx, Donna, for the link. Jogged my memory about the earlier 'backsplash' thread. And thanx to Greg for reposting his kitchen mod - great job. L 'n D
Old 03-24-2009, 08:29 AM   #20
Francis,
The pancake fan mounting material (Starboard <sup>tm</sup>) piece was cut large enough to completely cover the rough opening created for the exterior vent hole. I sized the holes for the fans based on the size of the particular fans I used (I think that they may well be a pretty standard size, but I don't know that to be absolutely true). To mount the new fan board against the bulkhead, I used a couple of small 90 degree angle brackets, one on each side. I used screws to mount the angles to the Starboard material, and then drilled and pop-riveted the whole thing to the bulkhead surface. Please remember to not drill through too far so that you don't punch a hole all the way through the exterior fiberglass trailer wall. I only drilled through the interior backsplash fiberglass liner only. There is enough space between the two surfaces, due to the ubiquitous carpet bulkhead liner, to accommodate the rivet head between the two walls (inner and outer). Then, just caulk your seams with white silicone sealant to dress the edges for appearance and to prevent oily smoke and such from working its way under the board. Just makes it easier to wipe down and keep clean. Hope this helps.
Greg
FOUND: two-burner gas stove for Boler François P. Classified Archives 6 11-10-2009 12:43 PM
WANTED-3 burner stove top Christi V. Classified Archives 2 03-20-2009 06:45 PM
Need 2 burner stove D Martin Problem Solving | Owners Helping Owners 2 12-14-2006 12:19 PM
eBay 3-burner stove Frederick L. Simson Classified Archives 0 02-01-2006 10:43 PM
Bucket for One-Burner Stove Legacy Posts Camp Cooking, Food & Recipes 2 10-11-2002 12:56 AM
