Hooking up new LEDs?? - Fiberglass RV
Old 06-15-2009, 10:00 PM   #1
I'm in the process of hooking up new LEDs. I'm assuming that I hook the yellow (auxiliary wire) to the tail (running lights) not the stop n turn? Please someone correct me if I'm wrong. Its a 1972 Boler.
Timmy T is offline   Reply With Quote
Old 06-16-2009, 06:28 PM   #2
Roy in TO's Avatar
One can't assume anything based on colour alone. It may be original from a number of sources or have been rewired a number of times. The best way is to test it either with a spare bulb or circuit tester.
The wire for the running lights will go on and off with your headlights.
Old 06-17-2009, 10:28 AM   #3
james kent's Avatar
Trailer: Boler 1984
It sounds like perhaps someone has replaced the original wiring with a trailer, off-the-shelf wiring kit. In the Document Center, at the left under Resources, there are two 1976 Boler manuals. Neither one shows a yellow wire but does insicate what circuits are in a Boler. As Roy said... Use a circuit tester, or a meter, to check your wiring. Then keep a list of what you have for future reference.
Good Luck
LEDs Byron Kinnaman Problem Solving | Owners Helping Owners 14 11-13-2007 08:26 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
» Trailer Showcase
Scamp
GingerB
Eggcamper
Judy K
