Originally Posted by Dennis Clinton
Meghan: isn't that bulb a two filament bulb? If it is, one of the wires coming out goes to the taillights, and the other is for turn/brake. The ground wire should hook to the socket side or the metal strip it attaches to. Disconect the new ground you attached and then hold it to the metal side of the socket while the lights are on to see if you get something(hook the two wires coming out to the two wires coming out of the trailer).
Dennis,
Thanks for the info. You got us thinking and we figured it out based on what you said. All the stuff on this is old and not done right and looking at it can be confusing to see what is original and right and what was done the wrong way.
We currently have all the
tail lights needed, although we realize that they need to be replaced as soon as we get back, due to corrosion. The clearance
lights also all need replacing due to corrosion. We are buying them out of every store that we can find that sells them.
Thanks for all the wonderful help guys!!!
