Hooking up the Play Pac-trailer lights?????? - Fiberglass RV
Old 07-19-2011, 01:09 PM   #1
Meghan's Avatar
Trailer: Play Pac
We are trying to put the play pac on the road and cant figutr out how to get the trailer lights to work. We have the 7 pin connector but nothing is working, no signal, brake, nothing. Where do I even start???? Thanks...I will have lots of questions getting ready for the big inspection on Tuesday!!! ugh
Meghan is online now   Reply With Quote
Old 07-19-2011, 01:40 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hi, Meghan
First thing I'd check, and you probably have, is the tow vehicle: have you used the 7-pin before and found that it works properly?
And if so, are you getting any electrical activity at the trailer, even a flicker?
If not, check all trailer connections, beginning with ground.
Come to think of it, check for a bad ground anyway- it's often the culprit in situations like this.
Francesca
Old 07-19-2011, 01:55 PM   #3
Meghan's Avatar
Trailer: Play Pac
Hi, Meghan
Francesca
The tow vehicle used the 4 pin and we have an adaptor to go from 4 to 7 pin. Just checked on the guys progress...he think he is doing something wrong, but no idea what.
Old 07-19-2011, 02:12 PM   #4
Hi, Meghan
If you've used the four-pin before and it worked properly, the problem must lie with how the trailer wiring is hooked up.
That's IF you've established that you have a proper ground.
Note that your four-pin will only supply lights, stoplights, and turn signals.
Does the trailer pigtail look original?
I ask because I'm surprised it has a 7-pin connector.
I thought Play-Pacs came without brakes...but I've been wrong before.
Lots of times!
Francesca
Old 07-19-2011, 02:20 PM   #5
Hi, Meghan
Lots of times!
Francesca
Note: If you want a charge wire you'll need at least 5 wires.
Old 07-19-2011, 02:28 PM   #6
Meghan's Avatar
Trailer: Play Pac
Hi, Meghan
Lots of times!
Francesca
I'd does have brakes. We aren't hooking them up yet, someday when we tow with a possibly smaller tug. We will try to figure out I'd we have a proper ground. it isn't as easy as it aounds
Old 07-19-2011, 02:30 PM   #7
Meghan's Avatar
Trailer: Play Pac
What is a charge wire? I apologize for being so nieve, my ex did all this stuff and I'm vlueless
Old 07-19-2011, 02:38 PM   #8
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Old 07-19-2011, 02:50 PM   #9
Meghan's Avatar
Trailer: Play Pac
This is what the instructions say. What is the beat way to see if I have a proper ground?
Old 07-19-2011, 03:00 PM   #10
Re the wiring diagram posted- I don't know if that's the right diagram for this trailer- that vintage usually used blue for brakes...
It could be this one...
OR
It could match the trailer end diagram here in the document center- it's indexed for Scamp, but my Trillium uses these paths, too
Fiberglass RV - Document Center - WiringDiagram_7-Pin_TrailerEnd
Only way to know is to check each wire..
And, Meghan- those instructions you just posted- are those for the adapter, or what???
Francesca
Old 07-19-2011, 03:21 PM   #11
HMMM
On closer inspection...
I believe the two diagrams I posted are in fact the same wiring scheme- the color one must be looking straight on at the car end...
Francesca
Old 07-19-2011, 03:44 PM   #12
Meghan's Avatar
Trailer: Play Pac
So power out of tug is good. I have an adaptor. What good so the diagrams do me while I am not getting power to anything??? I am sorry for not understanding. Any tups about ground???
Old 07-19-2011, 03:54 PM   #13
Well-
If I'm reading this right, and those instructions are for your adapter...
I'm guessing your problem may be that the adapter is wired differently than the trailer.
Your instructions indicate that yellow is left, green is right, and brown is tail/stop.
The diagrams I posted (very likely how your trailer's wired) show that RED is left, BROWN is right, and GREEN is tail/stop.
And what's that language on those instructions about a "ground wire to the trailer frame" all about???
Francesca
Old 07-19-2011, 04:25 PM   #14
Meghan's Avatar
Trailer: Play Pac
Well-
Francesca
If the wires didnt match up...ex green claims to power the turn lights on the adaptor, but green on trailer is for runners, wouldnt SOMETHING work??? Like we try to turn on running lights and signal lights go on? Like something should come on even if it is all crazy and not doing what it is supposed to do.
"Ground wire to trailer frame" well...what I know is 1. it was previously grounded to the frame and 2. I heard that is what I am supposed to do. Do you know different? 3. I cant find anything in the instructions about that, I see "Ground- white-attach to vehicle ground point"
*sigh*
lights
Play Pac Bonnie General Chat 161 06-24-2016 02:47 PM
1973 Play Pac Trailer For Sale $2950 Stephen T. Classified Archives 15 07-02-2011 09:32 PM
Play pac refridgerator Meghan Problem Solving | Owners Helping Owners 4 06-02-2011 05:40 AM
Pac and Play...so it begins Meghan General Chat 4 05-31-2011 11:17 AM
New (old) Play Pac owner. James McKnight General Chat 3 05-08-2010 06:51 AM
