Hot H2o Heater Switch - Fiberglass RV
Old 05-16-2012, 09:43 AM   #1
Trailer: 1980 16 ft Scamp (Restored)
Our 1980 Scamp has an electric Hot H2O heater. There is a of-off switch on the heater mounted under the cabinet. We have a problem remembering to shut it off. I would like to install a lighted switch on the front of the cabinet that will remind us it is on. Could someone provide a wiring diagram explaining how this would be wired in? We have such a switch wired in to the water pump.
Lawrence W is offline   Reply With Quote
Old 05-16-2012, 10:06 AM   #2
The heater is 120VAC and the water pump is 12VDC so they are different. I purchased a receptacle at Lowes that has a AC outlet and a RED light above it and installed it in a location where it would fit, B out of the way and highly visible at the same time. If you do not know electrical wiring I advise you employ an electrician to do the work.
Old 05-16-2012, 10:26 AM   #3
fusedlight's Avatar
Trailer: 16' 1998 Scamp
In both cases, a simple light wired from the HOT wire of the switch on the close side to neutral (in the case of the AC circuit) or to ground (the DC circuit) will work just fine. That's really all those lighted-when-on switches do. Your friendly Radio Shack will have the appropriate lights.
fusedlight is offline   Reply With Quote
Old 05-17-2012, 08:35 PM   #4
Hot H20 Heater Light
Thanks for the tips.
Lawrence
On/Off Hot Water Heater Switch Diane D Problem Solving | Owners Helping Owners 14 10-01-2013 03:00 PM
hot water heater cyndi H Problem Solving | Owners Helping Owners 11 08-13-2013 12:50 PM
Casita Hot Water Heater Greg G. Modifications, Alterations and Updates 3 05-10-2011 09:14 AM
Water heater on / off switch? Keith Williams Care and Feeding of Molded Fiberglass Trailers 11 06-01-2009 08:21 PM
Hot water Heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-30-2003 02:14 PM
