hot water heater - Fiberglass RV
Old 09-05-2013, 08:17 AM   #1
Trailer: 13' scamp
hot water heater
My newly purchased 16' scamp has a non functioning water heater. I want to remove it to use the space for a microwave. It appears that it can be removed by drilling out the rivets that hold it to the body on the outside. PO had already disconnected the water lines. Has anyone done this? BTW the posts on this site are great! Thank you to all of the folks that share their knowledge.
john in flushing is offline   Reply With Quote
Old 09-05-2013, 09:07 AM   #2
Trailer: 2014 Escape 21
Virginia
John
John in NC just pulled his W/H for repair, contact him through P.M. he should be able to give you some good pointers. I found my leak . You also have to cap off your gas line, I would have that done by a qualified Gas tech. There is a 4 way gas connector under the right dinette seat where this could be done. West Marine sells hatches which may fit the hole in the side of the trailer. You could also check with Scamp for a window cutout to make a panel to cover the hole.
Eddie
Old 09-09-2013, 10:01 AM   #3
Trailer: 13' scamp
hot water heater
The heater had to go. I drilled out the rivets, pulled the unit out through the outside wall and removed the flakeboard shelf that supported the unit. PO had added a pressure tank in the water line. I took that outa also. There had been leaks from an unknown source so I took out the water tank and dismounted the water pump. I'm about to redo all connections, vacuum out all of the moldy crud, wash everything with a bleach solution and paint the floor after it's thoroughly dried. I''ll fasten a painted wood panel on the inside of the opening and use the old outside vented cover to fill the opening. Oh and carefully cap the gas line too.
On/Off Hot Water Heater Switch Diane D Problem Solving | Owners Helping Owners 14 10-01-2013 03:00 PM
hot water heater cyndi H Problem Solving | Owners Helping Owners 11 08-13-2013 12:50 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
hot water heater problems Lou & Lora E. Problem Solving | Owners Helping Owners 1 12-30-2005 06:00 PM
Hot water Heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-30-2003 02:14 PM
