Hot water in a trillium? - Fiberglass RV
Old 04-07-2008, 08:30 PM   #1
Andrew D.'s Avatar
Trailer: 1976 Trillium 13 ft
Hi, I have a 76 Trillium 1300 and I would like to add hot water for the sink. I thought of installing a little propane or electric water tank somewhere in the trailer. Any cues or ideas how to do this?
-Thanks!
Andrew.
Andrew D. is offline   Reply With Quote
Old 04-07-2008, 08:44 PM   #2
Alf S.'s Avatar
Hi: How about a tall slim garage sale coffee urn... take out the percolator basket/stem and plug it in and turn the spigot out over the sink???
Old 04-07-2008, 09:14 PM   #3
Andrew D.'s Avatar
-I never thought of that one Alf, but I'm looking for a more permanent option like Atwood or suburban water heater. Anyone knows the thankless water system ?
Old 04-07-2008, 09:47 PM   #4
Daniel V.'s Avatar
Trailer: 1974 Trillium 13 ft
There isn't much empty space inside the counter unless you give up something else, if that's the location you had in mind. Looks like you would probably need at least 1 cubic foot for the smallest units. I'm curious to see other answers, though. My fridge happens to be pulled out, so here's a pic of the small nook inside my counter between the fridge and the furnace.
Daniel V. is offline   Reply With Quote
Old 04-08-2008, 07:54 AM   #5
Here's a couple of previous topics:
Instant Hot Water Heaters, Do they work
Tank less water heater
Old 04-08-2008, 08:01 PM   #6
Andrew D.'s Avatar
Thanks, I'll take a look now!
Old 04-08-2008, 08:40 PM   #7
Andrew D.'s Avatar
[quote]There isn't much empty space inside the counter unless you give up something else, if that's the location you had in mind. Looks like you would probably need at least 1 cubic foot for the smallest units. I'm curious to see other answers, though. My fridge happens to be pulled out, so here's a pic of the small nook inside my counter between the fridge and the furnace.
Attachment 12570
-My Trillium doesn't have a propane furnace -we use a small portable electric heater- I was planning installing the water tank at that place, beside the fridge under the sink. Depending on the unit size, it might fit.
Old 04-09-2008, 03:07 PM   #8
Andrew D.'s Avatar
After reading post from members concerning tank less water system, I think this would be a interesting solution for my needs. Did any of you have a propane unit in a trillium or similar trailer? How much could cost the unit and how difficult is it to install one? Any suggestions on brand? -Thanks!
Old 11-26-2020, 11:52 AM   #9
New Hampshire
Originally Posted by Donna D. View Post
why do these links only take me back to the full forum list? I don't see it linking to the specific topic mentioned....
June in NH is offline   Reply With Quote
Old 11-30-2020, 09:27 AM   #10
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Probably because they are from 12 years ago and the site has changed since then.
Old 11-30-2020, 06:53 PM   #11
https://www.fiberglassrv.com/forums/...ter-94248.html
I have a Fastar that cost less than $100 and you can buy several others for less. Some of the guys have quick connects on the water lines and hang them on the outside when they want to use the heater. I made a stainless steel box with Lexan front to put mine in, but most don't do that.
These small cheap water heaters work pretty well and I have used mine since I rebuilt my Scamp 5-6 years ago.
trillium
Trillium City Water Inlet Woes David Swinnard Plumbing | Systems and Fixtures 32 02-19-2018 05:11 AM
Water infiltration in my trillium (not window problem) Johny Bg Problem Solving | Owners Helping Owners 5 05-10-2010 06:45 PM
Water in my Trillium 1300 Darren Pettis Problem Solving | Owners Helping Owners 8 11-04-2009 06:31 PM
1976 Trillium Rocker Water Pump Bill C Problem Solving | Owners Helping Owners 12 04-25-2008 06:48 PM
Trillium water tank drain John Perry Problem Solving | Owners Helping Owners 5 10-15-2007 08:59 PM
