hot water tank - Fiberglass RV
Old 05-26-2011, 01:45 PM   #1
Trailer: Bigfoot 25B25RQ
BC
hot water tank
On our outing in March the (electric ignition) hot water heater seemed a little fussy to start, and it had been so before on previous trips. I had intended to look at it when we were back home but I forgot about it completely.
Over the May 18 weekend the hot water heater failed to start altogether and I remembered the problems we had the previous times. On inspection I noticed the T-Stat tab had rusted through and broken off.
I had imagined an expensive fix at a dealer, but with a bit of research I realized it was an easy fix to peel back the protective rubber covering of what I now know as the thermostat, replace it and the thermal cut off fuse (it looked worn) at the same time. 5 minutes in all.
mike_bc is offline   Reply With Quote
Hot Water Tank Drain Tamid Problem Solving | Owners Helping Owners 13 05-17-2011 01:20 PM
B1700 hot water tank dribbles Peggy Problem Solving | Owners Helping Owners 0 09-12-2010 08:05 PM
Hot water coming out of the cold water side Matthew A Problem Solving | Owners Helping Owners 0 06-01-2010 09:37 AM
Hot Water tank done...split wide open DwayneR Problem Solving | Owners Helping Owners 3 05-10-2009 05:28 AM
Hot water tank pressure release valve Steve Nentwig Problem Solving | Owners Helping Owners 3 04-08-2007 04:38 AM
