How & Where to install a TV in Scamp - Fiberglass RV
Old 03-12-2012, 09:52 PM   #1
Pat Phil's Avatar
Trailer: 1999 Scamp
I just bought a 1999 16ft Scamp. I would like a small flatscreen TV in it. Any advice for what location works best? Will I need to add a wood post to attach a swing arm to? What things/parts do I need to make a TV work inside my camper? Will it work without an attenna on top? I am completely new to all this as you can see. Any advice. Thanks so much!
Pat Phil is offline   Reply With Quote
Old 03-13-2012, 05:50 AM   #2
Hi Pat, welcome to FiberglassRV. I don't typically carry a TV in my trailer, but understand there are those that do. So, I'll leave that discussion to the experts, but wanted to take the time to welcome to the forums. You'll find lots of help here.
Old 03-13-2012, 08:45 AM   #3
honda03842's Avatar
Name: Norm and Ginny
We place our TV in the Driver's side rear corner. There it is viewable from the bed and from the couch.
We carry a satellite dish, mostly because we're gone for very long stretches of time. Therefore we have no antenna. Others on the site have experience with that.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-13-2012, 10:13 AM   #4
Tim Wood's Avatar
Trailer: Class B for now
NY
I have seen some mount a two or tree piece pole to a mount on the rear bumper, and @ the belly band another attachment to help stabilize the system. Maybe someone here has a picture that would be worth, well a 1,000 words.
Old 03-13-2012, 11:02 AM   #5
Ed Harris's Avatar
Hi Pat and welcome.where in Mo are you?
The spot where you mount the TV will depend somewhat on which 16' Scamp layout you have,do you know?
The spot Norm uses will be OK if you have the same layout that he does but would not be the best if you have the Side Dinette layout for example.
Regardless where the TV goes yo can not really use an inside antenna in your Scamp as there is metal foil insulation inside the walls under the "Rat Fur" covering the walls.
This prevents any inside antenna from getting the job done.
So that leaves you needing an antenna outside either on the roof or somewhere else.
How you do it just depends on your needs and how you see the nuisance factor of an antenna that you need to put in place each time you park but that you can more easily adjust for best performance or the convenience of a roof mounted one that may be more limited in performance but a lot easier to live with?
I would suggest searching here and reading about this as this is one of the most talked about subjects on here. There are lots of posts and pictures to give you some ideas.
Make Sense?
Ed
Old 03-13-2012, 11:16 AM   #6
Trailer: scamp 13
don't be in a hurry for now. camp a bit and check out what others are using. that way when you do decide you will have some practicle experiances to work from.
plus,,,,by then you may find out your not missing having it and spend that money on something else,,,,say a romantic camping trip for two????
Old 03-13-2012, 11:18 AM   #7
Trailer: scamp 13
two other options,,, a lap top computer or a portable dvd player.
both can play movies for you and no worries about an antenna.
Old 03-13-2012, 12:03 PM   #8
Name: Larry and Mitzi
Trailer: 1972 ECO
We used the top part of the closet for the tv and radio/dvd, built a wooden insert with the mount in it. The cable hookup is on the outside of the camper and will also accomodate an antenna. The TV goes back into the closet where the 12 volt and 110 plug are. We made a padded cover with snaps for travel.
casey67 is offline   Reply With Quote
Old 03-13-2012, 12:15 PM   #9
Trailer: 1972 ECO
Does anyone know why I changed to "commercial member"? I'm not and don't know how it changed.
Old 03-13-2012, 07:50 PM   #10
Matt in SV's Avatar
Smile
There should be an explanation in your PM mailbox, Larry. Some icons were added to identify members with goods and services who might be interested in posting in a dedicated forum. If this is an error, you can mail an administrator or visit the Help desk.
Regards,
Matt
Planning our next Escape!
Old 03-13-2012, 08:21 PM   #11
Trailer: 1972 ECO
Thanks for the info. I have no PM with explanation. I sent an email to one of the administrators. I couldn't find where to access the help desk.
Old 03-13-2012, 09:13 PM   #12
Administrator
Mary F's Avatar
So sorry, Larry. Yours is a similar username to "Larry,C" who requested the commercial member status. We'll get it straightened out, ASAP. Thanks for the heads up!!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 03-20-2012, 12:27 AM   #13
peterh's Avatar
Coby makes under-cabinet HDTV/DVD/AM/FM units that fit very well in our Scamp 5er kitchen and runs on 12v. Ours is a 10" unit; they also make a 15" and 7" units that sit on the same base. Some additional details are on our install are listed in this post.
Old 03-20-2012, 01:08 AM   #14
I mounted mine on the overhead bin at the rear.
Shademaker 8 foot Awning Install 13 Scamp Greg A Modifications, Alterations and Updates 29 04-23-2016 04:15 PM
Yet another Scamp window A/C closet install. Allen Howell Modifications, Alterations and Updates 6 08-23-2014 05:39 PM
Fantastic Fan Install & Heater Repair barryra Modifications, Alterations and Updates 25 02-19-2011 09:31 PM
Scamp AC install Gary Little General Chat 2 06-01-2006 08:58 AM
My 13' Scamp A/C in closet install Bob H Modifications, Alterations and Updates 9 03-29-2006 06:18 PM
