How are the wires routed for the lights? - Page 2 - Fiberglass RV
Old 04-16-2011, 12:19 PM   #15
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Question
Originally Posted by GeorgeR View Post
If your lights are on 120V circuit than a non-contact detector, such as Greenlee listed above, will work. If your lights are on 12V circuit than the tone generator with amplified probe would work. These instruments are more expensive than the 120V non-contact probes but for tracing RV wires they are indispensible. This one is reasonably inexpensive Amazon.com: Gardner Bender GET-4110K Wire Tracker: Home Improvement
I use the Extech 4018 - Amazon.com: Extech 40180 Tone Generator and Amplifier Probe Circuit Finder Kit: Home Improvement
I accidently drilled once through the main power line while installing a house alarm; it took many hours to fix the damage.
George.
Hi, George
Have you used the amp probe to find 12v wires?
My husband has one and we couldn't make it work on the trailer 12v system.???
Francesca
Old 04-16-2011, 01:04 PM   #16
Hi, George
Francesca
I used my Extech in RV and at home on any wire, alarm, 120V conduit, LAN, etc. None of these tracers would work on a 12V circuits if tone generator is not properly connected to the wire to be traced. Line voltage, such as 12V DC or AC, will not trigger the receiver, it is the tone transmitter properly connected to the wire to be traced which emits the signal detectable by the receiver. If you had problem with your unit I would assume you had a defective tracer. These tone tracers are very common tools.
George.
Old 04-16-2011, 01:22 PM   #17
George.
I guess what I should have said was that we were trying to do the same thing Kip is- find the physical location of the wire in a cabinet.
My husband's tool did "trace" the wire from point to point- but we already had that info. It's real useful for making wiring diagrams etc., but it doesn't generate a "map" kind of thing.
Maybe his is an older generation of this kind of tracer-
Thanks-
Francesca
Old 04-16-2011, 05:10 PM   #18
Herb Sutton's Avatar
Trailer: 2002 Casita 17 ft Spirit Deluxe
The lights are 12v. They receive power from either the battery or the converter. If they were 120v they wouldn't work when dry camping.
I installed a 12v flourescent to those wires and it has worked well for 5 trips.
Herb Sutton is offline   Reply With Quote
Old 04-16-2011, 05:17 PM   #19
Well, that's what I think, too. but now that I look at Kip's posts I see that he hasn't really said so.
Seems like if they were 120v you'd be able to feel the housewire through the padding, though.
Francesca
Old 04-17-2011, 05:17 AM   #20
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
I've used good old duct tape in a pinch.
Since it's flexible though it's more a visual guide rather than a mechanical stop like the doohicky.
Your tubing idea's a good one- I've promptly stolen it and added it to my stash of in-case-I-need-this workaround tools!
Francesca
I generally use tape. It seems to work good enough for most situations.
The only time it seems to fail is when the situation is critical. The hole needs to be "this" deep and no more. Then the bit seems to find something to grab onto, and dig in.
Kip
Kip in Ga. is offline   Reply With Quote
lights
Connecting all those wires. CD Smith Problem Solving | Owners Helping Owners 4 09-09-2013 03:27 PM
HELP! Wires ALL over the place!!! J.S.Lahm Electrical | Charging, Systems, Solar and Generators 6 09-11-2012 06:10 AM
wires from hubs? Joe Steadman Problem Solving | Owners Helping Owners 5 08-23-2010 08:55 AM
BATTERY CONNECTOR WIRES UNDER FRONT SEAT?? Mary Lynn K. Problem Solving | Owners Helping Owners 4 05-06-2007 08:39 PM
Electrical Dilemma (Crossing fingers and not wires!) Legacy Posts Problem Solving | Owners Helping Owners 13 06-06-2003 09:03 PM
