How cold should the AC be? - Fiberglass RV
Old 07-10-2013, 02:19 PM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
I have a 1999 Casita with roof top AC.
How cold should the air be if I put a thermometer right on the exhaust vent?
Old 07-10-2013, 02:47 PM   #2
I was taught that with automotive A/C that you can expect about 20 degrees below the outside air temperature. I have a couple thermometers for A/C use that have a probe to stick into the air outlet, and they show the cool range to be between 48 and 60 degrees.
Old 07-10-2013, 03:14 PM   #3
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
One can test the unit's performance with ordinary room-air thermometers, too.
Here are some instructions for doing so from a very illuminating page on the subject of RV A/C ( link to source)
The RVer can perform a temperature performance test with two thermometers. One is used for ambient room temperature going into the A/C filter and the other thermometer is to measure the cool air exiting the discharge vent closest to the A/C unit. The A/C should be set to maximum cold and should run for at least 30 minutes.
The factory specification is approximately 20°F cooler air exiting out the discharge than the ambient room temperature entering into the filter. Air conditioners only remove the heat from the air, so if your RV temperature inside is 90 degrees the discharge temperature would only be approximately 70 degrees.
Francesca
Old 07-10-2013, 03:32 PM   #4
ShawnKK's Avatar
That should all depend on your unit (a/c unit). Under size or over size. Yes general rule of thumb is 20 under the outside temp. I know for a fact I can get 30 under outside temp easy. But I have a fairly new unit. 5000, 8000, 9000 btu units will work but what is it working in?
I am very very happy with what I have but I like it cold.
ShawnKK is offline   Reply With Quote
Old 07-10-2013, 04:04 PM   #5
It's twenty under intake temp, Shawn. Not necessarily outside temp.
Since many such units draw from inside the rig, further cooling can/will occur as the room air being fed into the unit itself cools.
Francesca
Old 07-10-2013, 04:34 PM   #6
ShawnKK's Avatar
Understand , but if you have a undersize unit or a unit that is not installed right like on the floor you will only get so much.
A unit on the floor will only pick up the cooler air and not the hotter air from the ceiling. So it wont work as good as if it is installed higher.
Old 07-10-2013, 05:36 PM   #7
honda03842's Avatar
Name: Norm and Ginny
To improve the efficiency of our floor level AC unit we place a fan in front of the AC unit and blow the output of the AC unit towards the rear, adding a mixing function.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
How cold does your frig get? Kevin K General Chat 9 06-06-2011 03:28 PM
Cold in the south Davie B General Chat 29 02-05-2011 10:51 PM
How COLD is too COLD Gerry General Chat 11 02-05-2011 12:06 AM
getting cold in CO but.... ronsmith100 General Chat 4 10-08-2008 08:32 PM
Cold coffee Lyndon Laney Jokes, Stories & Tall Tales 8 01-15-2007 01:29 PM
