How did you build your rear mounted spare tire holder - Fiberglass RV
Old 01-01-2014, 11:05 AM   #1
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
I have a perris pacer that came with a tongue mounted spare. I have seen pics of some rear mounted tires . Are these a factory option or self designed. I currently care the spare under the perm rear bed to help lower tongue weight . This loses a tremendous amount of storage. The rear bumper is a fiberglass material so i was looking for some ideas as many units appear to have the tire mounted to the fiberglass shell.
I have called scamp but they have never returned my calls. If anyone has done this or ordered a bracket that mounts above the bumper i woild greatly appreciate any advice or pic
alan H is online now   Reply With Quote
Old 01-01-2014, 12:23 PM   #2
papa-t's Avatar
Glade Valley, North Carolina
Spare Tire Bracket & Nuts
Our Scamp has the tire mounted on the rear with three bolts. You can purchase one from Scamp parts; Spare Tire Bracket & Nuts $22.00 plus shipping. You would just have to drill the holes in the rear. The plate would be mounted from the inside with the bolts sticking through to the rear. Of course you would need to use some sealant also. Hope this helps.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 01-01-2014, 07:07 PM   #3
Trailer: Fiber Stream
Most spare tires come mounted on the rear of the fiberglass body from the factory as standard equipment. Many thru-hull bolts are attached through a large plywood piece to provide stiffness and strength so that the bolts don't rip through the fiberglass. This is all done under the "rat fur" or "elephant skin" or whatever your interior wall covering material is. The one papa-t references is a pretty standard design.
Old 01-01-2014, 08:24 PM   #4
Yeppers. Frederick is correct. The rear end of my Scamp has a big ole piece of plywood fiberglassed in and the spare tire piece that papa-t referenced is bolted through that piece.
What you don't want is a spare hanging off a wimpy bumper. Every bump you'd hit causes the spare to move back and forth and that in turn could cause the bumper/frame to flex enough to develop cracks.
Old 01-01-2014, 08:40 PM   #5
papa-t's Avatar
I havn't seen behind the rat fur. So I certainly wouldn't want you to mess anything up. So the one pictured could be used against the FG with the plate I would guess. Scamp could answer that question for shure.
Old 01-01-2014, 09:18 PM   #6
I would build something off the trailer frame if possible. Like a rear receiver, attached to at least 2 frame members. Attaching through the fiberglass without adequate molded in reinforcement doesn't sound very good to me. Just my opinion. Our tow vehicle, a Honda CRV, has an outside mounted spare, so the trailer spare fits in the Honda inside spare well. Was there a problem with the tongue weight with the tire on the tongue?
Old 01-02-2014, 06:58 AM   #7
Trailer: 1980Trillium 1300
...Here is mine, self made for a 1300Trillium, just a share...
Old 01-03-2014, 03:06 PM   #8
Wow.....how did anyone ever figure out what I was talking about with all of the misspelled wording in the title. Anyway thanks to all for your quick response. Has anyone over used the bracket that Papa t suggested and mounted it thru a board on top of the ensolite without fiberglassing it in...in other words just sandwiching the fiberglass between the tire on the outside and the wood/bracket on the inside
Old 01-03-2014, 04:28 PM   #9
Trailer: 77 Scamp 13
Don't know the Perris Pacer but if you have brackets screwed into the back for a swing down dining table that becomes a bed you probably have a piece of wood under the ensolite. Might be worth checking.
You could consider putting the wood under the ensolite in the back so that the wood is hidden. I have not found it too hard to work ensolite loose from the wall using a plastic and a metal putty knife/scraper at least in the pieces I removed to re-do front bunk mount. Pretty easy to glue back when done, helps if you don't totally remove it from the wall. Just peel to were you need access, with some ensolite still attached to wall it avoids ensolite contracting so you have to glue it back in sections stretching as you go.
I think you need the wood to be large enough to spread the load out over a broad area.
Old 01-03-2014, 05:57 PM   #10
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I haven't used the bracket, but I have used the technique you describe for other heavy applications. It works just fine- the purpose of the plywood is to strengthen/ spread the load over the fiberglass- "glassing on" doesn't really provide any more strength.
Do be sure to use through bolts/nuts and not just wood screws, though- and squinch 'em up well.
Old 01-03-2014, 06:18 PM   #11
papa-t's Avatar
Thats why I love this forum. One persons opinion leads to "been there done that" suggestions. The plywood would certainly be of great importance to stablize the structure. I just assumed that plywood was at the rear due to the dinette area. If it's not you would need it as suggested above. Good luck.
Old 01-03-2014, 07:12 PM   #12
The plywood piece on the back of my Scamp is about a foot square. Since it's under the reflectix and the rat fur... I can't see it, but if I run my hand over the rear I can feel it. I can't imagine there's any reason for it being fiberglass to the body other than the fact it keeps it from moving. If you think you'd be happy having it exposed... it should work just as well as being fiberglassed and hidden. Done right, it wouldn't be Fugly... maybe add a magazine holder (etc.) to it at the same time... like you did it on purpose?
Old 01-03-2014, 10:29 PM   #13
And there is always paint or stain to go with interior that works with the suggestion that Donna made on adding an accessory to the wood so it looks like it is all by design.
You might want to consider a double layer of plywood. One closest to the wall with holes for bolts and the plate, a second over that to act as a "cap" that hides the hardware.
Old 01-03-2014, 11:01 PM   #14
IllAnnoy
If your Perris Pacer has 4-bolt wheels, you will need a bracket with two mounting bolts instead of the three shown in the late model Scamp part.
They may have the old style, but it would be easy and much cheaper just to fabricate your own.
They do make a ready made bumper mount bracket, but it would require bumper modification braced to an extra frame crossmember.
Can you show me how the spare tire is mounted on your Boler, or Trilli jenniferm Problem Solving | Owners Helping Owners 12 01-01-2015 11:30 AM
Why You Should Never Weld a Rim with a Tire Mounted Thomas G. General Chat 13 08-10-2013 07:07 AM
Spare Tire Holder Bonnie Towing, Hitching, Axles and Running Gear 18 08-30-2007 03:04 PM
Spare Tire Holder on a 16' UHaul Vacationer Kevin A Problem Solving | Owners Helping Owners 10 03-19-2007 12:18 PM
new tires, rv place did not hang spare tire potteralice Problem Solving | Owners Helping Owners 13 11-27-2006 09:29 AM
