How do I adjust Scamp electric brakes? - Fiberglass RV
Old 09-21-2009, 05:56 PM   #1
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
I just installed my Prodigy P3 controller and went out to test things out. Before I left, I heard buzzing at the brakes when the manual lever was applied but when I took it out, they are not really grabbing. I'm supposed to start at 6.0 volts and apply full manual voltage until the brakes lock up. Even at 12.5 volts, the brakes do not lock up nor do they slow me down in a way that would be effective in a hard braking situation.
How do I adjust the actual brakes or check for other problems that might be present? I read about a star wheel - is this similar to what my old VW had? Is there a tutorial out there or instructions that I missed in my search? I just couldn't find much on it except for someone saying that you should know what you are doing before you adjust them. Thanks for any assistance.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 09-21-2009, 06:55 PM   #2
Greg A's Avatar
Trailer: 2015 Escape 19
Hey Bryan,
You should just have a star wheel adjustment. Here is a video that goes over changing brakes and towards the end of it they go through the star wheel adjustment..... The part you want is at 4:30 and is pretty short.
Enjoy ur trip.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 09-21-2009, 08:44 PM   #3
Bryan L.'s Avatar
Dang, that was a short little segment about that! Thank you for finding that. I always forget about etrailer and all of their great videos. I went out and adjusted them but I still need to test them out. Wife is out of town and kids are sleeping so it will have to wait until the morning.
I also want to include an message that I got from another member. I just want to paste it here so that others that perform a search for this topic in the future can benefit from it as well. I'm OK with the brakes not "locking up" when I apply full voltage but they're not even really slowing me down. I would think that I should feel some pretty good braking action with just the trailer brakes, correct? Anyway, here's the other message: (and yes, I guess I do have towing on the brain as the message points out!)
Hi Bryan,
Just a couple of quick notes about specific points in your topic about adjustment challenges.
Some trailers will not lock the brakes at any setting level. I found this was true for my Boler, and some brake and brake controller manufacturers acknowledge this their documentation; it is not necessarily a problem. It is important that the brakes not lock up, and the lock-up setting is just a maximum, not necessarily a target. My setting is around 7 volts for full effort, but when manually applied at that setting the trailer's brakes certainly do not lock up the wheels.
Braking the whole rig with just the trailer brakes should not be enough to reasonably stop the whole rig, unless the trailer is very heavy compared to the tug. The Scamp's brakes should be doing their share of the work, so with just those brakes (set to stop a ton at hard-stop rate when the brakes are fully applied) the whole rig (maybe three tons, depending on your tug) will be only gently slowing down. The idea is that when you stop normally, the Scamp's brakes will do their part, the tug's brakes will do their part, and the whole rig will stop almost as effectively as the tug would by itself.
The slack adjustment of trailer drum brakes is just like that of a car (presumably including your old VW)... except that even those cars which still have drum brakes also have self-adjusters, so they only need to be adjusted when new brake shoes are installed, and adjustment is thus no longer a routine service item. Just like with the cars, a screwdriver or similar tool is inserted in a slot and the wheel is turned until the shoes touch the drum, then backed off until the drum just turns freely with no brake drag. If they are not adjusted correctly, they may have too much slack to take up when applied, and thus may not be as effective as they should be.
I don't know what brand of axle and brakes you have, but they are all about the same, and Dexter Axle has some great service information on their website (which is also linked in FiberglassRV's Helpful-Links section). There, now you "know what you are doing"....
I hope that's helpful,
P.S. You have towing on the brain... you're topic subtitle says you are leaving in "tow" days...
1991 Scamp 16'
Old 09-21-2009, 10:32 PM   #4
Greg A's Avatar
My brakes don't lock up either when I set the brake controller, but they do noticeably slow the rig. There was a thread back a bit on the brakes not needing to lock up when adjusting the brake controller, but can't locate it at the moment.
Maybe the guru of finding old threads, Donna, can dig it out. I also use the manual lever if the trailer starts fishtailing which I've experienced about twice with any seriousness and it brings the trailer right back in line so I know my brakes are fairly effective.
Owner:
Old 09-22-2009, 05:48 AM   #5
This one? Setting Your Trailer Brakes Good stuff written by Pete Dumbleton at the very bottom
brakes, scamp
Troubleshooting electric brakes Roy in TO Towing, Hitching, Axles and Running Gear 4 08-05-2009 06:34 AM
Electric Brakes Steve Smith Towing, Hitching, Axles and Running Gear 10 08-23-2008 05:36 PM
Electric brakes Greg Janke Towing, Hitching, Axles and Running Gear 11 03-31-2008 11:45 PM
electric brakes Hub Bru Care and Feeding of Molded Fiberglass Trailers 1 01-30-2007 11:19 AM
Electric brakes Greg Janke Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
