How do I change bulbs on Running lights? - Fiberglass RV
Old 03-28-2013, 10:39 PM   #1
backporchinjuly's Avatar
Yukon
Hi All,
I'm a new owner of a '75 Boler that's in pretty good shape but needs some TLC. The first issue is that I have two running lights (one on each side) that are out. I've been reading the wiring and grounding threads with interest (thanks) but I thought I'd start simple and check the bulb. Except that I don't know how to change the bulb. Or if I even can. It's a Bargman sae-p2-a-81 replace bulb. I'll attach a picture. Help please?!
backporchinjuly is offline   Reply With Quote
Old 03-28-2013, 10:51 PM   #2
FTTRV's Avatar
Trailer: tp
Use a screwdriver to remove. Each light has a slot to put a screwdriver in to pry lens off. Yes the bulb could be out. You can buy bulbs or the complete light at Canadian Tire or Princess Auto and more places.
Chuck
Old 03-28-2013, 11:10 PM   #3
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
While you have the lens off, if the fixture is ok, I would clean up the contacts with some emory cloth (sand paper) and maybe wipe a bit of dielectric grease on them before you put in the new bulb. One of our Trillium lights was out and I discovered a broken bulb and bulb rusted to the fixture.Took a pair of pliers to remove the rusted bulb. A little cleaning, a little silicone grease, and a new bulb and good as new. YMMV
Reid Larsen is offline   Reply With Quote
Old 03-29-2013, 04:28 AM   #4
Mark J's Avatar
Trailer: 13 ft Scamp 1999
As long as we are on the subject (of running lights)! When I purchased our trailer several years ago the man I bought it from switched the wiring from 7 pin to 4 pin and everything works EXCEPT the side marker lights. We were in a hurry at the time, darkness was upon us; I still haven't looked into it much.
Any ideas on what might be the problem?
Mark J is offline   Reply With Quote
Old 03-29-2013, 06:23 AM   #5
It's possible that it is a combination of bad bulbs or bad connections, marker lights are notorious for being a problem. The other possibility is that the marker lights are on a separate wire from the tail lights at the plug and didn't get connected. A voltmeter or simple test light can help in locating the problem. Or bring it to me and I'll fix it for you. [note that I don't know your location, probably on the other side of the country from me]
mary and bob is online now   Reply With Quote
Old 03-29-2013, 07:09 AM   #6
Trailer: 2014 Escape 21
Virginia
Mark
My guess is the PO got confused with the wiring color codes and ran the four pin wires directly to the tail lights and cut the wire to the trailer running light wires. In the case with the running llights it matters where and how you connect to the Scamp wiring. All the side marker lights tie into the running light circuit. The four pin running light wire is brown on the scamp it is green. I suggest installing a wire junction box under the goucho bench from e-trailer and clean ip the rats nest of wiring.
Eddie
See page 13>
http://www.scamptrailers.com/Portals...nersManual.pdf
Old 03-29-2013, 08:18 AM   #7
My suggestion: As long as you're going to the trouble to take the fixture apart, why not just throw the old ones away and replace them with some newer LED types? Incandescent running bulbs seem to have a tendency to burn out pretty regular. Measure the distance between the mounting holes and I'll bet there's some perfect replacements available online. The LED types usually are completely sealed and should last another 30 years or until the next rebuild. And trying to diagnose electrical problems without a multimeter can be an exercise in frustration. They're only $5 at Harbor Freight.
Terry G is offline   Reply With Quote
Old 03-29-2013, 09:07 PM   #8
Since you're north of the border, check out Princess Auto: here's some yellow running lights: 2-7/8 x 1-1/2 in. LED Mini Clearance/Marker Light | Princess Auto
and some red ones: 2-7/8 x 1-1/2 in. LED Mini Clearance/Marker Light | Princess Auto
If these aren't the right size, there are lots to choose from. I agree, you'll probably pay as much for the bulbs as the entire assembly. Something to consider!
Old 03-29-2013, 10:10 PM   #9
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I'm another big LED fan. I gave up on regular bulbs, especially with the car trailer. A camper might not be so bad, but I'm not even trying. With the empty car trailer and rough roads, it was killing bulbs regularly, usually at least one a trip.
It's less load on your vehicle circuit, and usually brighter, I know mine sure are.
Old 03-31-2013, 06:01 PM   #10
Yukon
Thanks for all the advice. The lenses popped right off. The bulbs were ridiculously corroded (clearly the PO had been driving around without working running lights for awhile). I cleaned up the contacts best I could and put some dielectric grease on them and . . . It didn't work. Fortunately a little wiggling and I could seat the bulbs where they made better contact and worked!
I appreciate the advice about LEDs. I think I'll go that route eventually - just not at the top of the list yet.
Thanks again for all the advice. I love this forum. This is what the Internet should be all about! I'll try not to ask too many dumb questions!
Old 03-31-2013, 06:06 PM   #11
No dumb questions are ever asked, truly. It's the ones that aren't asked that cause dumb mistakes/problems.
No running lights biw314 Electrical | Charging, Systems, Solar and Generators 14 12-01-2012 07:13 PM
Running lights Carol Crawley Towing, Hitching, Axles and Running Gear 6 04-12-2008 11:22 PM
Running Lights jrnutpaul Problem Solving | Owners Helping Owners 15 11-20-2006 07:57 PM
new running lights Dan Quinn Problem Solving | Owners Helping Owners 24 05-08-2006 06:06 PM
Running lights Carol Crawley Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
