How do you reach it? Center Trim on Roof. - Fiberglass RV
Old 04-07-2013, 11:10 AM   #1
D Davis's Avatar
Trailer: u-haul ct13
Virginia
REALLY? DUHHHH... Trying to replace the Center Trim on the roof of the Uhaul CT 13. No ladder is enough... Cannot see how you guys reach the center trim on these trailers without climbing on the roof. How have others done this?
NEVER MIND...Went to a shorter ladder and can lean over and reach some of it now ...I'd delete this but don't know how....Duhh
D Davis is offline   Reply With Quote
Old 04-07-2013, 11:53 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I confess that I've had a few anxious moments reaching the center.
Old 04-07-2013, 12:50 PM   #3
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
View pix on p. 43 of thread "Not PoliGlow--time will tell." I am unable to copy here at this time. You need a section of scaffold, either two frames and two x-braces OR a modern unitized rental unit, an aluminum or wood trestle plank to span the scaffold frames end to end (parallel to trailer), a plywood or dimension lumber plank spanning from scaffold plank to the central Pullman section of roof.
There are other staging lashups that can be knocked together. I don't like any of them as much as the scaffold and "gang plank."
jack
Old 04-07-2013, 01:25 PM   #4
D Davis's Avatar
Virginia
HA! Thanks you guys...You'd laugh if you saw this I know...Just got it cleaned up and putting on all but the top back. Need scaffold for that I think, and don't have the bolts cut on the old solar. That will be another day. Went with BLACK TRIM. I like it!
Old 04-07-2013, 01:53 PM   #5
rabbit's Avatar
Delaware
Diane, glad you're getting on with the TrimLoc. UHauls and Burros both benefit in strength from the beam sections of the Pullman roof as well as from the short vertical centerline flanges and the thickening of the roof by the bonding of inner and outer hulls. I would be much less concerned with deflecting the roof or hull joints by placing my weight on it than I would be about sliding or falling off.
jack
Old 04-07-2013, 01:58 PM   #6
Thomas G.'s Avatar
Originally Posted by D Davis View Post
.....Went with BLACK TRIM. I like it!
Can't wait to see the pitchers.
Old 04-08-2013, 07:59 PM   #7
Trailer: 2008 16 ft Scamp
We use our 2 little giant ladders with their plank between them to wash/wax the top.
RachelW is offline   Reply With Quote
Old 04-08-2013, 08:16 PM   #8
D Davis's Avatar
Virginia
Good Idea! Thanks!
Old 04-08-2013, 09:00 PM   #9
Pam Garlow's Avatar
Trailer: U-Haul 1985
I have white trim which is too 'white' against my creamy UH camper. I think I need to change it out to black. Too bad it doesn't come in something cool like chrome, or colors!! What size did you get, Diana?
Old 04-08-2013, 09:13 PM   #10
D Davis's Avatar
Virginia
Pam, I think you could paint the white...that's the beauty of it.
I ordered it quite a while back, but I keep a little notebook with notes on the trailer.
Note says 3/8-1/2 and I think I ordered it from "R&P Carriages" I always search for the best price... their number is 815 357-3292 you need 21 feet. that gives some sqirm room. It is really good Quality I am sure they have it in white also. I had thought about white because it is difficult to paint black rubber.
The old stuff was coming loose and was REALLY REALLY BRITTLE Broke while I was removing it.
Old 04-08-2013, 09:16 PM   #11
D Davis's Avatar
Virginia
Now I want a Black spare tire cover. Just a want not a must have. They only thing is the trim does not meet up to the window, with black it is so obvious. Goes unnoticed with white.
Old 04-08-2013, 09:26 PM   #12
When I did my Fantastic Fan installation, and removed the solar panel and repaired the leak under it I used one of those rolling stairs things. I have one that's 6 feet tall and it's nice because you can lean off the end without pushing it over like a step ladder would. The Uhaul roof is only rigid near the center, leaning on the curved part pushes it in. I had thought a scaffold type arrangement would be nice but didn't want to take the time to build one. Also considered working out of the loader bucket on my Case tractor, but the stairs thing was the quickest and easiest. Be careful using a ladder, leaning over the top of the trailer could take weight off the feet and let them slide out.
Old 04-08-2013, 09:39 PM   #13
rabbit's Avatar
Delaware
Funny that our Burro originally had black TrimLoc which got painted white so I have both with no expenditure whatsoever. I like it white even if a bit dingy. Our weather has warmed up after Easter and I'll be starting on a good scrub down and Red Max refresh later this week.
jack
Old 04-08-2013, 09:44 PM   #14
D Davis's Avatar
Virginia
Originally Posted by mary and bob View Post
" Be careful using a ladder, leaning over the top of the trailer could take weight off the feet and let them slide out."
Bob, thanks this is so true, a very careful, painter friend of mine broke his arm and colar bone like that.
Also I have a dent on the front top of camper...did not know how it got there...thought a tree branch...now maybe after thinking about this, I may have done it leaning the ladder and my weight against it. Oh No!
Protecting The Roof & Roof Vent Covers , AC, This Winter ???? John Cole Care and Feeding of Molded Fiberglass Trailers 25 01-15-2013 05:57 PM
Removing Roof Rack and Patching Screw Holes in the Roof Roger M Modifications, Alterations and Updates 4 02-08-2012 11:40 AM
Why is the Roof Vent off center? Brian Scott Problem Solving | Owners Helping Owners 14 03-24-2008 08:21 PM
The $49,000 15' Airstream "Design Within Reach" Patrick M. General Chat 12 06-06-2007 06:00 PM
Removing center trim? Legacy Posts Problem Solving | Owners Helping Owners 16 06-09-2003 06:41 PM
