how does that stabilizer work? - Page 2 - Fiberglass RV
Old 09-23-2013, 12:14 AM   #15
Brian B-P's Avatar
I rented a tent trailer with two of those things on the back... and no instructions, and no bar. I did as Byron describes - it worked, but I wouldn't choose them, and didn't when I added stabilizers to our Boler (I used BAL Light Trailer Stabilizing Jacks).
They do have the advantage of retracting completely above the frame bottom, which may be important if mounted at the very back.
Old 09-23-2013, 05:24 AM   #16
Trailer: asdf
Alabama
Originally Posted by kdhanso View Post
Thanks. That's what
I'm doing and neither stabilizer latches.
jwcolby54 is offline   Reply With Quote
Old 09-23-2013, 05:47 AM   #17
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by jwcolby54 View Post
Thanks. That's what
They don't actually click when they lock, it is a sliding, jamming mechanism. The way I use mine is to step on the foot to pull it all the way down, then lift on the bumper slightly which causes the stabilizer to extend just a little more, then lock when I release the bumper.
Old 09-23-2013, 06:33 AM   #18
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
That's an elegant method of operation, Tom. Sprezzatura trumps information occasionally. I use the bar only to put the extension foot in firm contact with the ground, usually only one click. Byron's method of firming up the extension feet by taking a turn or two on the tongue jack handle does the same. Ten turns on the handle is enuf to transfer weight from the tires to the stabilizers. Whether frame distortion or breakage is likely at that point or not, I wouldn't do it on principle. They look like jacks, operate like jacks, are sometimes referred to as jacks, and aren't jacks. Not everything that can be done should be!!!
jack
Old 09-23-2013, 06:47 AM   #19
honda03842's Avatar
Name: Norm and Ginny
I don't know if this makes a difference.
We have the stabilizers drop onto 4x4s cube. As a result they are rarely fully extended. We use a 10" ratch wrench extender to firm them up once down.
We do find that with an extended stay one or the other will loosen a little and we just give them another hit.
The 4x4s came with our trailer and have a whole thru them. They store on a threaded rod that goes thru the rear bumper, This threaded rod is actually one of the bolts that holds the pasenger side stabilizer to the bumper. It's a handy location that uses unused space.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-23-2013, 06:59 AM   #20
Trailer: Casita 17 ft DLX SD
Same Method
Originally Posted by ericw View Post
I used to have these on all 4 corners of my previous non-fiberglass trailer and was not a fan of them.
Now I have a Scamp and like them because I use them much differently. I only have them on the back (like most Scamps). I level the trailer with the rear jacks up, move the tongue jack down 10 turns, put the jacks down in the rear, and move the tongue jack back up 10 turns. The 10 turns take a little weight off the tires and puts it on the jacks. Depending on your tongue jack you made need a different number than 10.
If I am doing it wrong, please let me know, but it sure is faster and easier.
I used the same method with my Scamp .When I picked up my Casita at the factory and was going through orientation , they recommended Eric's method for deploying the stabilizers . Trying to use the pry bar when half the time the holes don't line up is a pain in the A __ __
Old 09-23-2013, 07:20 AM   #21
Trailer: asdf
Alabama
I will try this. If it si going to work this seems the easiest way to work them.
Mine were somewhat corroded and I sprayed them with a WD40 corrosion inhibitor. Perhaps the "jamming mechanism" is now lubricated
Old 09-23-2013, 11:06 AM   #22
SilverGhost's Avatar
Trailer: Egg Camper
These stabilizers really are sensitive to being clean and straight. If bent or rusty they won't work that well. Good thing they are cheap!
Sounds like yours maybe a little bit of both?
Jason
SilverGhost is offline   Reply With Quote
Old 09-23-2013, 12:14 PM   #23
honda03842's Avatar
I believe the instructions are not to lubricate. One of mine came slightly bent so it doesn't drop down. I use the ratchet extension to put it down. I also use it on the other side to tighten.
Here's a picture of our blocks, not the threaded rod above for block storage.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-23-2013, 12:30 PM   #24
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
We use a "lego" under ours. Oops. We cleaned and lubricated. We are with Donna on them being messy, just too lazy to change anything.
Nancy
Nancy is offline   Reply With Quote
Old 09-23-2013, 02:12 PM   #25
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
jack
We had these stabilizer jacks on our Little Guy Teardrop. Admittedly, the dry weight was only 1080 Lbs but the recommended method for changing a flat was to lower the tongue jack as far as it would go, lower the stabilizer jacks to the ground and crank the tongue jack back up until the tires came off the ground. Then change tire and reverse the operation. Definitely NOT recommended for long term storage.
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 09-23-2013, 04:51 PM   #26
Trailer: asdf
Alabama
I put them down last night.cranked up on the tongue jack and they both locked.
Old 09-24-2013, 04:25 AM   #27
kdhanso's Avatar
Glad you got them to work.
Ken
kdhanso is offline   Reply With Quote
Old 09-24-2013, 11:16 AM   #28
Trailer: asdf
Alabama
I would feel better if I did "get them to work". Unfortunately I didn't do any particular thing.
Maybe it was just dropping them down, then cranking the tongue up.
Maybe it was the dressing up in red shoes, clicking my heels 3 times and whispering "there's no place like home". (I was desperate!!!)
Maybe it was the string of unrepeatable adjectives... (kidding)
Stabilizer Jacks Lawrence W Modifications, Alterations and Updates 0 10-02-2011 06:09 PM
Brackets for Stabilizer Jacks Jane D. Problem Solving | Owners Helping Owners 9 09-09-2011 04:10 PM
Stabilizer Jacks jimtesla Care and Feeding of Molded Fiberglass Trailers 21 06-19-2010 02:39 PM
Stabilizer Jack question DannyH Problem Solving | Owners Helping Owners 28 10-09-2009 02:06 PM
Stabilizer Jacks Legacy Posts Modifications, Alterations and Updates 17 05-08-2003 05:04 AM
