How I made a boler screen door - Fiberglass RV
Old 09-06-2013, 02:03 PM   #1
lespnd's Avatar
Trailer: 1300 Boler -The Pine Cone
Hello everyone
I have seen many screen doors made on this forum and others, so I thought I would share the basics of how I made mine.
Keep in mind I am not a carpenter but I did take a shop class in high school 25 years ago. Attached are some pics of how I went about it. For those who are avid wood workers I have a lot of respect for your craft. I did all I knew and although it could have been better, I think I did pretty good. I hope it helps those at least try as they really do look nice. I think anyways.
Cheers
Noel
lespnd is offline   Reply With Quote
Old 09-06-2013, 03:20 PM   #2
Thomas G.'s Avatar
Awesome, Noel. If you aren't a carpenter, you are on your way.
Old 09-06-2013, 04:17 PM   #3
You may not be a carpenter but you did a really nice job, something to be proud of. Even better is your write up and pictures of your progress.
You didn't learn that 25 years ago in high school.
Old 09-06-2013, 04:18 PM   #4
Roy in TO's Avatar
I can attest that it looks as good in person. Noel would pass my finish carpenters exam. Better work than I've seen on million dollar homes.
Old 09-06-2013, 10:45 PM   #5
Trailer: 73 Boler 13 ft
Beautiful work, Roy. I assume the screen door swings in, so wondering if you find it takes up a lot of room inside. Did you put some kind of quickly removable hinge pins, for cooler days of camping, or will you leave it on 365 days a year.
Peggy is offline   Reply With Quote
Old 09-06-2013, 11:06 PM   #6
Oops I mean nice work, NOEL. I guess my now being a "senior member" doesn't mean smart member!
Old 09-07-2013, 05:29 AM   #7
lespnd's Avatar
Thank you for the kind words. As far as the mounting goes, it is mounted permanently, which is our preference. I dislike bugs so we generally keep the door shut at all times to keep them outside. This is a custom 2 person wood trailer on the inside so as I opens onward, it sits up against the Dometic coolcat at the bottom and a custom dresser, then cupboard on the top. I could have went bi-fold to save inside room but didn't like the look of having a seam up the middle of the door. I would have had to choose a different design. It crossed my mind in the beginning though.
Noel
Old 09-07-2013, 06:26 AM   #8
cpaharley2008's Avatar
Please post some other pictures of your custom 2 person wood trailer, with such a good job on the door, I can imagine what other things you may have done.
Jim
Never in doubt, often wrong
Old 09-07-2013, 07:20 AM   #9
lespnd's Avatar
I can not take the credit for the majority of the work done in my trailer, although I did do some. I bought the trailer with the interior done by a very talented member on this forum. Here are some pics of the interior. Changes where made over the past 3 years since I've owned it. I still have to take new pics. I will post an update when done.
http://www.fiberglassrv.com/forums/m...albums736.html
http://www.fiberglassrv.com/forums/m...albums726.html
Noel
Old 09-07-2013, 07:25 AM   #10
Jim Bennett's Avatar
I am an avid woodworker, and would be pleased to make that door myself. Good job, Noel.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-07-2013, 07:49 AM   #11
lespnd's Avatar
It must be noted that I choose to use pine to match the rest of my boler interior. As a result the door size fluctuates with the humidity as most woods do. However, this one moves a lot! So much in fact that it binds. I have had to make adjustments to the sides, <Ehem...hand planer..> along the way to free up the door. Perhaps a different type of wood would have been more forgiving but when it;s pouring down rain, I don't think it would matter that much. I have seen some people even use plywood for the side panels as it is more stable. Material is definitely something to seriously consider when planning this. FYI: It took me about a month in my spare time to build this.
Noel
Old 09-07-2013, 08:07 AM   #12
Noel, if you plane it to have a clearance of at least 1/8" all around, and have it close against a stop, you should not have any issues, either with binding, or sealing against the stop.
The species of wood used would only have a wee bit of difference in expansion and contraction. Yes, plywood is more stable, but for the most part, not as nice looking. Some of the heavier entrance doors we build use a heavy plywood core, with a 1/4" lamination of solid wood on each side to give them stability.
2017 Escape 5.0 TA
Old 09-07-2013, 08:23 AM   #13
lespnd's Avatar
Hi Jim
Thank you for that. Yes, the stop is my trim and I believe my clearance is less than 1/8". I will definitely look into that. Cheers.
Noel
Old 09-07-2013, 09:23 AM   #14
Very, very nice!
Old 09-07-2013, 10:20 AM   #15
Trailer: 1984 UHaul CT13
Great job Noel,
Have you created a new business? Custom screen doors by Noel.
keekers is offline   Reply With Quote
Old 06-14-2023, 11:18 AM   #16
Trailer: Boler 17'
How did you attach it inside the boler? I was thinking about doing this but the only thing I can think if is to drill into the vertical metal supports on either side of the door to mount the sides.
scamp53 is offline   Reply With Quote
boler
50$ screen door DannyH Modifications, Alterations and Updates 38 07-05-2023 08:51 PM
screen door highlandsgirl Problem Solving | Owners Helping Owners 9 08-06-2010 10:31 PM
Boler Screen Door Poject Con Modifications, Alterations and Updates 5 10-17-2009 10:44 AM
Screen door for 13 foot Boler Dave M Problem Solving | Owners Helping Owners 5 07-22-2006 08:57 AM
