How is a vent supposed to be attached to a roof? - Page 2 - Fiberglass RV
Old 08-21-2010, 07:50 AM   #15
Trailer: 1960s 10 ft Burro
Our basic question is how do you attach the plywood ring for vent installation to the ceiling? or do you just have someone hold it in place until you finish screwing down into it through the vent flange? I know, I know, we are so ignorant but we don't want to do this wrong and have more problems down the road....literally! Thanks for any guidance here.
Rose Feys is offline   Reply With Quote
Old 08-21-2010, 08:20 AM   #16
Mark Shaffer's Avatar
Trailer: 2004 Jayco Talon toyhauler/ 1985 Burro 13 custom.
There is no wood framing on your 13' Burro, only fiberglass. You will have to make a wood frame to go on the inside of the roof to screw the vent into. You will have to screw through fiberglass down in to the plywood to secure the vent on top. Also the trim for the inside of the vent will also attach to the wood to make a clean look for the install. You can use a construction adhesive or have someone hold it until you have it secured with the screws.
Mark Shaffer is offline   Reply With Quote
Old 08-21-2010, 08:46 AM   #17
Originally Posted by Rose Feys View Post
Hi-we are trying to install our Fantastic vent fan ourselves, and I have searched the threads and there is often a reference to wood for screwing into, your photo and thread mention a plywood ring...was that ring something you added yourself? How did you affix it to the ceiling? We are scratching our heads , the factory customer service told us to build a wood trim to screw into , much like the threads I have searched here...but no one is saying how to affix the wood to the fiberglass ceiling...we are feeling real stupid right now. Can someone give us some advice, direction or encouragement?
Rose,
Make a ring out of 3/8" or 1/2" plywood that has the same dimensions as the flange on your fan. The flange sits on the roof (with putty tape between,) screws run through the holes in the flange, through the roof, and into the plywood ring. You end up with a sandwich, plywood ring on the bottom, then the fiberglass roof, then the flange sitting on top. A little hard to visualize, hope this helps. Feel free to email me with further questions.
Mike
Mike Reynolds is offline   Reply With Quote
Old 08-21-2010, 09:19 AM   #18
Rose, see Alf's post with pics (post #6) in this thread. It shows the wood you're talking about. FanTastic Vent - How To Install
Old 08-21-2010, 09:33 AM   #19
Joe Z's Avatar
New River AZ
Great Thread as i need to install a Fantastic Fan into a Hi-Top Conversion Van and had no idea about the plywood ring inside..... I'm plenty handy and just need to be shown once and this really helped.
Paul who originally posted: I have to admit that silicone looks really sloppy and if you get no help from the installer maybe you could just go vertically with a razor-knife around the outside perimeter (being careful not to cut into the gelcoat) and peel away the outside of that cut to get a neater look.
Joe
Old 08-21-2010, 09:37 AM   #20
Thank you so much everyone!! We have been bickering over the installation for the last couple of days and your responses clarify it all...Thanks again! Now out to install it.
Old 09-12-2010, 11:42 AM   #21
Smile Fantastic Vent Fan is installed in Burro!
Wanted to say thanks to all, and to provide the update that our vent fan is installed, rain tested and is WONDERFUL! The interior wood trim frame worked like a charm and we are happy happy happy! Now to fix that pesky leak in the front window!
Old 09-12-2010, 09:03 PM   #22
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
Obviously they didn't think you would look on your roof.
Cyndi B. is offline   Reply With Quote
Old 03-07-2011, 01:04 PM   #23
Trailer: Boler, 2 Serro Scottys
I made a wooden frame and siliconed it to the interior ceiling. Then I screwed my vent down from above. Pics here: The National Serro Scotty Organization
nkroes is offline   Reply With Quote
Old 03-07-2011, 02:04 PM   #24
Hey Nancy, thanks for sharing the link to your Boler. Wow, big improvement... looks very nice! When I first saw your message about using Silicone , but then I saw what you did . Glad you used it on the inside and not the outside... butyl tape there. Smart lady!
Old 03-08-2011, 04:47 AM   #25
Yes, was just using it to hold the wooden frame to the ceiling so I could screw into it from above. I never use silicone on a trailer - RV ProFlex if I need to seal anything and yes, butyl tape behind all doors, windows and vents. Having a fiberglass egg trailer is new to me - my other trailers are Serro Scottys, having done frame up rebuilds on two and soon to start number 3. The National Serro Scotty Organization and The National Serro Scotty Organization and The National Serro Scotty Organization
Old 03-08-2011, 06:16 AM   #26
Joe Z's Avatar
New River AZ
I looked thru your first link about your Scotty rebuild.......
You do extremely Good Work.
Joe
Old 03-08-2011, 08:37 PM   #27
Roland H's Avatar
Trailer: 1973 Trillium 13ft
Manitoba
WOW, great work and thanks for the links. You will do great with the Boler!
Roland
Roland H is offline   Reply With Quote
Old 03-08-2011, 09:20 PM   #28
Trailer: 1971 Amerigo
A friend in the fiberglass fabrication business uses a hot glue gun (Not the gun - the hot glue) to hold parts in place while tabbing or otherwise attaching them more permanently. Might work for the plywood ring.
Peter_Crowl is offline   Reply With Quote
Roof Vent Kevin K Modifications, Alterations and Updates 24 10-09-2014 09:48 AM
Roof Rack attached to Frame jarrett beatty Modifications, Alterations and Updates 3 07-14-2010 12:34 PM
Roof Vent Mike Whitney Problem Solving | Owners Helping Owners 10 02-27-2010 08:18 AM
Roof Vent gregziglar Modifications, Alterations and Updates 3 08-08-2006 03:37 PM
new roof vent ?? Dan Quinn General Chat 7 01-11-2006 10:29 AM
