How is a vent supposed to be attached to a roof? - Fiberglass RV
Old 06-02-2010, 10:57 PM   #1
Paul McEwan's Avatar
Trailer: 1976 Trillium 13 ft
Send a message via MSN to Paul McEwan
We took our trailer in to (remains nameless at the moment), to have a fantastic fan (and heater) installed in our 76, 13' Trill and we're scratching our heads at the gobs of caulking used.
My understanding is bitchathane tape should be used with some kind of mechanical fastening finished with a thin bead of caulking. It looks to me like they have used the caulking as the preferred method of fastening.
Before we fire off emails, can anyone enlighten us to these fan retrofits and method of installs?
The heater install is worse, (one thing at a time)
Paul McEwan is offline   Reply With Quote
Old 06-02-2010, 11:29 PM   #2
Raya's Avatar
I hate to sound negative, but that looks completely inappropriate to me.
How it should be installed is that you prepare the two mating surfaces (underflange of vent and mating camper surface) with something like acetone or denatured alcohol, and then, if you are using butyl tape, you apply the tape to the full width of the underflange of the vent. If using caulk, I would set the vent in place and then put blue tape on the camper outside of the flange contact area, to make clean up easy, and then lift the vent out again and put the caulk on the underflange, then set it back in place (because with caulk you want squeeze out -- but you *remove* said squeeze-out!).
Next, you install the fasteners (screws, rivets, or etc.), and tighten them in an alternating pattern. Then you clean up any excess sealant (remove it). Then you are done. There is no need or, indeed, desirability (IMO) for any caulk on the outside. The sealant underneath the flange is what does the job. Anything on top usually indicates someone trying to put on a band-aid vs. re-sealing properly (years down the line). In other words, you should basically see no caulk or sealant when the job is done (except maybe some that is slightly "holding up" the flange - but none on the outside).
I'm sorry your vent came back to you like that.
Raya
Old 06-02-2010, 11:43 PM   #3
Thanks Raya,
I found this link on Fan Tastic Vent installs.
http://www.fantasticvent.com/faq/knowledge...to_install.html
(I never use silicone like it looks they they are)
I prefer your method. Wait 'till you see the furnace.
(my kingdom for someone who knows what they are doing)
Old 06-02-2010, 11:43 PM   #4
Matt in SV's Avatar
Before we fire off emails, can anyone enlighten us to these fan retrofits and method...
Here's a link to the installation guide at the manufacturer's site
It's very common, (and recommended here) to daub sealant over the screw heads. There are probably fasteners under all that silicone, but I agree it's a sloppy job.
Regards,
Matt
Planning our next Escape!
Old 06-02-2010, 11:48 PM   #5
Raya's Avatar
From another point of view: I come at it from a boating angle - in those installations (hatches, ports, cleats, etc.) we don't put caulking over the fasteners, and the aforementioned parts have to be able to withstand "green water" coming over them while pounding in a seaway. So I still feel that sealant under the flange is the way to go.
I don't meant to sound too opinionated, but it just galls me to see caulking globbed onto the top of something you just had installed.
Not that you should have to, but I'm sure you could make a tidy job of it yourself It's wonderful to find a skilled, conscientious craftsperson; but otherwise it can be the old "if you want something done right..."
Raya
PS: I am with you on the silicone - there is *always* a better sealant, in my opinion.
PPS: The furnace is... worse?!?
Old 06-03-2010, 06:51 AM   #6
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Paul McEwan... Here's a couple of pic's of how I did My MaxxFan install.
Alf S. North shore of Lake Erie The last pic. shows a closeup of the mount screwed thru the fiberglass shell into the ply ring sealed with auto fender (butyl rubber)sealer tape. I hope they help!!! Alf
Old 06-03-2010, 10:01 AM   #7
Paul are you saying they only fastened it with caulking no rivets or bolts? If thats the case I would go back and ask for at least a part refund - pay for the hole being cut out and forget the rest. Regardless of how they actually fastened it the caulking job is IMHO a pretty shocking coming from someone who is charging for their services. If it was mine I would then take it off and clean it up and re install it as it will come out a looking a lot nicer and probable a lot more leak proof. Trust me if I can do it you can do it! LOL
I installed mine last fall pretty well the same way Alf did his. Happy to report that it stood up to pounding rain this past week-end without a drop coming into the trailer.
Keep up your efforts it will all work out at the end of the day.
Old 06-03-2010, 10:27 AM   #8
Trailer: 2010 Scamp 16 ft
Although i dont have pictures at the moment, but for what its worth, I just picked up our new 16' Scamp two months ago from the factory and that is excatly how my fantastic fan is installed. lots of beads and globs of silicone.
edit: Ok after looking at your pic a little closer i would say that they went way to heavy on the silicone. My fan has a small bead around the perimeter and a glob on every screw head.
Christopher Phillips is offline   Reply With Quote
Old 06-03-2010, 10:41 AM   #9
Trailer: 73 Boler
Thanks Raya,
To bad your in Vancouver if you were on the island I could help you out.
K Slade is offline   Reply With Quote
Old 06-03-2010, 12:15 PM   #10
Thanks everyone. I just wanted to make sure because it is so deliberate. coming from a construction background i am now in marketing, living in the city it bugs the hell out of me that time and space limit me to having inferior work done. i strongly believe in maintaining as a green approach to ownership and if i had the space for the tools and work area, i would do it myself. is that the only way to refurbish these beauties? a change in entire lifestyle? i'm looking to re-build our van and camperize it too. vehicles don't need to be thrown away every 10 years but i am finding this too something DYI centric. (lack of capitalization and spelling errors to be blamed on the phone's keybord) cheers!
Old 06-03-2010, 01:20 PM   #11
Robert Johans's Avatar
Trailer: Nest Caravans
If you don't mind, allow me to toot my own horn. Check out my website, and this recent thread: http://www.fiberglassrv.com/board/index.ph...38632&st=30
If I can be of any help, let me know.
Old 06-03-2010, 05:10 PM   #12
peterh's Avatar
Which is why I do most of our home and trailer repairs and remodels. Most of those in the construction/handyman trade go for cheap and easy, not what's aesthetic or built to last. They're not craftsmen.
Old 06-03-2010, 05:21 PM   #13
Bud Kennedy's Avatar
Trailer: 1984 U-Haul / 02 Mazda pick up
I would demand at least a partial refund AND ask for them to pay to clean that mess up!
Thats the poopiest job I have ever seen from a "professional".
Bud Kennedy is offline   Reply With Quote
Old 08-20-2010, 04:04 PM   #14
Trailer: 1960s 10 ft Burro
Hi-we are trying to install our Fantastic vent fan ourselves, and I have searched the threads and there is often a reference to wood for screwing into, your photo and thread mention a plywood ring...was that ring something you added yourself? How did you affix it to the ceiling? We are scratching our heads , the factory customer service told us to build a wood trim to screw into , much like the threads I have searched here...but no one is saying how to affix the wood to the fiberglass ceiling...we are feeling real stupid right now. Can someone give us some advice, direction or encouragement?
Rose Feys is offline   Reply With Quote
Roof Vent Kevin K Modifications, Alterations and Updates 24 10-09-2014 09:48 AM
Roof Rack attached to Frame jarrett beatty Modifications, Alterations and Updates 3 07-14-2010 12:34 PM
Roof Vent Mike Whitney Problem Solving | Owners Helping Owners 10 02-27-2010 08:18 AM
Roof Vent gregziglar Modifications, Alterations and Updates 3 08-08-2006 03:37 PM
new roof vent ?? Dan Quinn General Chat 7 01-11-2006 10:29 AM
