How level is level? - Fiberglass RV
Old 06-04-2007, 08:17 PM   #1
DaveK's Avatar
Trailer: 2011 Escape 5.0
I bought a Toyota Tacoma (Off road package) and I'm having a heck of a time finding a ball mount with enough drop to get the trailer tongue perfectly level. With the 5 3/4" drop I've got at the moment the tongue has a slightly noticable rise, but only 1/4 - 1/8 of a bubble on the level -- depending on where I put the level.
Do I need to continue the search for the ultimate level or am I within reasonable tolerance?
Thanks.
Dave
DaveK is offline   Reply With Quote
Old 06-04-2007, 08:51 PM   #2
ddayton's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Send a message via Yahoo to ddayton
In my experience, nose down is better than nose up. Biggest impact of nose up is increased tendency to sway as weight is shifted to the rear. If unable to find an off the shelf ball mount check with a local welder, they should be able to fix you up.
ddayton is offline   Reply With Quote
Old 06-04-2007, 10:22 PM   #3
Gina D.'s Avatar
West Coast USA
I suspect your problem will cost around 10k $$$ or more.
Bigger truck = excuse to get a bigger bigfoot
"But Honey, it has to be PERFECTLY level.. or we will die!"
Old 06-05-2007, 06:17 AM   #4
Dave, try the Trailer Parts Superstore, they've got mounts with drops as much as 10 1/4" for less than $45. I think you'll find what you want for less than $30
Old 06-05-2007, 07:08 AM   #5
DaveK's Avatar
Shh! You're giving away my Master Plan!
Thanks all. I heard what I needed to hear. The search goes on, but now I have more clues.
Dave
Old 06-05-2007, 10:49 AM   #6
Pete Dumbleton's Avatar
I'd say you are close enuf right now IF it's a little nose down, not up. If up, then try to get a different "drop" on the ball mount bar. What I would do is go to WalMart, get a couple of likely bars and return the ones that don't fit -- If none fit, at least you will have a better idea of what to order on-line. Remember to pack the tow vehicle as you would for a typical trip, including passengers, because that may affect the ball height.
Old 06-05-2007, 03:33 PM   #7
Trailer: 17 ft 1991 Bigfoot
I would not what Pete said. You want the nose a little high so that when you load the truck you will probably be much closer to level.
Remember you have a big tow compared to yoru little Bigfoot. Even with my 17' Bigfoot, my Avalanche really is very tolerant and even with 4 people and lots of gear I can really go smoothly down the freeway at 70+ mph.
- Joe
Joe Mielke is offline   Reply With Quote
Old 06-05-2007, 05:48 PM   #8
Brian B-P's Avatar
My ball mount is chosen to have the trailer approximately level - erring on the side of nose down if anything - with minimal cargo load. With changes in load, I just inflate the Coil-Rite air bags inside my rear springs to maintain that attitude - the air adjustment really does make accounting for load changes easier.
Ball mounts are only available in reasonable increments, and I doubt sitting an inch low will matter enough to worry about it. One option for the perfectionist is to get a screw-adjustable ball mount (such as the one from Master Lock), if you are not using a weight-distributing hitch (which has it's own special mount requirements), but to me this is more bulk, weight, and complication than needed for the job.
Old 06-06-2007, 11:03 AM   #9
- Joe
Joe, I wasn't clear -- I meant to check the level with the tow vehicle packed and set it nose low under the actual conditions for towing, not to set it nose low with the TV empty.
BTW, everything all packed up and ready to roll as if for a trip is an excellent time to get the whole rig weighed at all axles and determine the tongue weight. It's a bit of an iterative process because proper tongue weight and TV load will affect the hookup level, so it may take some jockeying around to get it right.
As Brian points out, an adjustable suspension (air springs, air shocks, etc.) can also be used to fine-tune the towing level.
On The Level Gerry Care and Feeding of Molded Fiberglass Trailers 7 11-07-2007 04:24 AM
Will you Level with me? Frederick L. Simson General Chat 28 11-26-2006 02:00 PM
Need options for a level Burro MyronL Problem Solving | Owners Helping Owners 7 07-21-2006 05:08 PM
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 32 12-23-2005 11:57 AM
Water Level Steve L. Modifications, Alterations and Updates 2 11-15-2005 08:48 AM
