08-05-2019, 10:31 AM
Trailer: scamp 13
Wisconsin
How level is level
What are the tolerances for being level for a scamp 13 to be safe for proper operation of fridge? Also could anyone comment on typical maintainance for Dometic fridge. Thanks
08-05-2019, 11:03 AM
With newer refrigerators, level is not as critical as some older (20 years) units. If the trailer feels comfortably level to walk around in, you are probably good to go. I always carried a very inexpensive Harbor Freight plastic level that cost less than a dollar. I would first level the trailer side to side using blocks, then front to back using the tongue jack. Lots if time, I would not detach the trailer for several days and there would be some noticeable , but not inconvenient slope to the trailer, and the refrigerator worked well.
08-05-2019, 11:28 AM
Trailer: 2012 Escape 19
Another way to look at it: if you can sleep comfortably in it, it's level enough.
08-05-2019, 11:45 AM
Trailer: 1979 Boler 1700
Regarding level, a quick search found this:
"Thank you for contacting Dometic. The refrigerator should not be more than 3 degrees unlevel left to right, or 6 degrees unlevel front to back. We do not recommend having the unit unlevel for more than 1-2 hours as this can increase the chances of a blockage. However, we do recommend if you can, have the unit level at all times."
This was posted in 2017 in the irv2 forum by someone who owns a Dometic RML8555 fridge. They had emailed Dometic and received this response. If you want specific guidance on your fridge, email the manufacturer.
08-05-2019, 01:38 PM
Trailer: Sasquatch
Montana
6 degrees is a LOT. Even 3 degrees is pretty drastic inside the trailer. So yeah, as long as your fridge is fairly new, you're fine if you're comfortable in it. If I'm parking for more than 15 minutes and I can't find anywhere flat, I turn off the fridge.
There's a lot of info out there on fridge maintenance. The burner assembly is what needs to be cleaned about once a year. Burner jet, burner, and very occasionally the chimney flue.
08-05-2019, 02:10 PM
member
Isle of Wight
I've never been able to sleep comfortably in my fridge....
08-05-2019, 02:17 PM
Trailer: Roamer TC
If you can see the back side of the refrigerator you will see slightly slanted pipes, probably at less than 3 degrees slope. These are the issue. The liquid will get trapped in these if it is not able to run down the spiral pipes continuously. Liquid gets stuck and damage is done in the boiler part from lack of enough liquid.
As long as the pipes have a down slope you are fine.
You can see front-to-back there is more pipe than side-to-side so is the reason they give two different angles which you can be leaning.
I was surprised they said it could be out of level for so long. I always figures 10 mins would start the damage process. Is good to know if it is true.
While you are driving the liquid gets sloshed around so much that level is not a factor.
I think this is the refrigerator, not the trailer, dont get this confused. The two are 90 degrees rotation off each other if fridge is on a side wall. Trailer 3 degrees front to back, 6 side to side.
08-05-2019, 03:42 PM
Trailer: Sasquatch
Montana
You must be seriously pampered Mine suits me just fine.
08-05-2019, 08:10 PM
Trailer: Escape 21C
Casita
We keep plenty of 10" long 2x6 wood blocks for the purpose..keep that bubble "betewwen the lines" and no problemo..a bit head up for sleeping, but still w/in the bubbles.
08-05-2019, 09:37 PM
What bwand is you fwidge?...A Westinghouse??
08-06-2019, 07:43 AM
Trailer: Sasquatch
Montana
I joined the circus when I was young and trained as a contortionist...
08-06-2019, 09:57 AM
Trailer: 2017 Escape 17B
SW Virginia
Thanks aj. That seemed wrong to me as well.
Walt
08-06-2019, 12:33 PM
LOL......that was funny widgetwizard. Glad to see people's humor.
08-14-2019, 10:09 AM
fridge level
We use a simple 9" level to check whatever we can control (mostly front to back slope) in our 2009 13 ft Scamp. Never had a problem with the fridge. Years ago, had fridge in a van that NEVER seemed to work, and I suspect it was far more sensitive re: level than my 2009 Dometic is. (and of course I was much less informed....)
08-14-2019, 10:17 AM
Puget Sound, WA
I don't know that there is a lot of maintenance involved. Mostly we see people having issues with maintaining adequately cold temperatures, particularly with side-vented applications.
Here's a link to brief article with a couple of thoughts regarding operation and maintenance.
5 Tips For RV Refrigerator Maintenance
08-14-2019, 12:23 PM
Trailer: Vagabond
Nevada
I've always found it too cold to sleep in my refrigerator, my wife has hot flashes so she prefers it.
08-25-2019, 11:38 PM
Trailer: 1976 Prowler
Mine works quite well being out a 1/4 inch at 2 feet. Much more than that not so good. Hope that helps.......
