How much flex should a torsion axle flex, if a torsion axle could flex flex? - Fiberglass RV
Old 08-10-2014, 09:23 AM   #1
JeepScamp's Avatar
Name: Clay and Keri
Trailer: Eggert the Scamp
Hi all! Hoping someone can help me. I am doing the torsion axle flex test by having the Scamp hooked to the tug and having my wife bounce up and down inside. I have...maybe a 1/4 inch of movement in the axle way much more in the tires. How does this stand for the test? New axle or is this adequate?
Thanks in advance!!!!!
JeepScamp is offline   Reply With Quote
Old 08-10-2014, 10:10 AM   #2
Mike Magee's Avatar
Trailer: Li'l Hauley
I am not at all sure if one can tell much from bouncing up and down inside the trailer while it is stationary. Maybe others will know more. But I can say from past reading here that people tend to replace their Scamp axles when the arm angle has changed so much that one can no longer insert a fist vertically between the tire top and the wheel well above it. As the axle rubber ages, the whole thing droops. When you run the risk of having the tire bounce up into the wheel well and wear the fiberglass there, something must be done.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 08-10-2014, 11:06 AM   #3
JeepScamp's Avatar
Name: Clay and Keri
Thanks Mike! The problem is manifolded by the fact that the PO put 12" wheels on it. I don't really know the correct size. Scamp says the new ones come with a 13" wheel. No info that I've found about tire size. With the 12" 4.8-12's I can run my fist completely around the wheel well. I also don't want to buy new tires if the axle is shot.
Old 08-10-2014, 02:11 PM   #4
Trailer: 2015 Escape
I don't know. How much wood could a woodchuck chuck? Sorry. Couldn't resist.
Old 08-10-2014, 02:48 PM   #5
Roy in TO's Avatar
  1. Download the Torflex information http://dexteraxle.com/i/u/6149609/f/...nformation.pdf
  2. Take your tire off
  3. Determine if you have a Torflex
  4. determine your start angle
  5. Using jacks, blocks and people to bounce get the values for your axle on each side
  6. make your own decision or post results with pictures on how you tested and where you took measurements from
Old 08-10-2014, 05:03 PM   #6
JeepScamp's Avatar
Name: Clay and Keri
Glad you liked it Bob! Life's too short to not have a sense of humor.
Thanks Roy! I downloaded the PDF and am looking at it.
axle
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
What a torsion axle should not look like John and Jaci Care and Feeding of Molded Fiberglass Trailers 16 05-07-2010 01:19 AM
How much weight could a shelf hold in a Scamp closet? Bryan L. Problem Solving | Owners Helping Owners 7 06-03-2009 09:50 PM
Interlux users.. how much should I order? Geoff W Care and Feeding of Molded Fiberglass Trailers 3 04-25-2008 07:07 PM
