How often to grease wheel bearings - Page 2 - Fiberglass RV
Old 04-01-2014, 04:15 PM   #15
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I am of the mind that when you do pull the bearings, you should clean them up good before packing with new grease. Solvent and a stiff bristled brush does it up quick. I need to get a new bearing packer as mine got smashed, but they help with repacking the bearings fairly quickly, with less mess. In the past though, I have just mashed it in by hand.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-01-2014, 04:43 PM   #16
Trailer: Scamp 19
Thanks for all the replies. I do have my bearings repacked once a year in the fall or right after summer. I have the same guy that works on my truck do them as he is also a TT owner. I prefere to not have any troubles when on the road, and don't mind doing a little preventive maintenance before taking a trip.
I also use a laser themometer to check the wheel bearing heat at all gas, food, and doggie breaks. I have never had a temp over 106 degrees, and generally the other side is at 100 degrees, even after going 200 miles before stopping.
One thing I always do before traveling is wax the front of the trailer. The bugs that give up their lives, to make a mess on the front, clean off very easly. I also clean the solar panels before I leave on a trip (love those things). I also do the normal things like check battery water, propane levels, etc.
captsteve2002 is offline   Reply With Quote
Old 04-01-2014, 05:51 PM   #17
MC1
MC1's Avatar
I do the same thing. Also a quick check with the temp laser on the inlet line of the tranny cooler is a good idea too.
Old 04-01-2014, 06:36 PM   #18
deryk's Avatar
New Jersey
I probably should order 2 sets of replacement bearings and seals and keep them as backups. I do always check my hubs at each stop and even after the 500 mile trip down to ParkLiner they were only a little warm.....how do you check the break pads?
deryk
Old 04-01-2014, 06:53 PM   #19
If you have your wheel bearing inspected and repacked every couple years, you should not have to carry replacements. If there is any indication of wear, a competent mechanic will see that and replace them and they will last another six years or more.
Old 04-01-2014, 08:04 PM   #20
Takes a bit more than a hour for me but yes the bearings are cleaned first. That way you can check them for signs of abnormal wear.
Old 04-01-2014, 11:36 PM   #21
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
There’s a fellow over on the Caista forums named Larry Gamble that some of you may have heard of. He owns Little House Customs ( www.LittleHouseCustoms.com ) and he makes his living building/designing/installing various mods on Casita trailers. I feel certain that he has worked on more trailers than most of us will ever see. I’m confident that he is fully competent to make the following statements that I have compiled from several posts he made a few years ago.
"Buy a complete set of bearings before you go. Pack them in grease and triple baggie them along with a lot of paper towels. Don't leave home without them. Even if you can't do it yourself, at least you can provide the parts for the Good Samaritan that's offered to help you. If you want Timken bearings, they are three or four times as much money and, for what it's worth, current Dexter axles come with Chinese bearings. I have no problem with that. I'd carry a spare even if I was running Timkens. The good news is Chinese versions are probably made from old Studebakers and Maytags."
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 04-01-2014, 11:51 PM   #22
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Steve, I like your discription of the Chinese bearings but I had to laugh. Didn't all the Maytag commercials say they would last just about forever .
Old 04-02-2014, 06:07 AM   #23
Raz
Raz's Avatar
Vermont
I found this out when I bought replacement brake drum kits. I wonder how long Timkin will be around? Raz
Old 04-02-2014, 08:17 AM   #24
I suspect Timken will be a round for awhile. They are the brand that more often than not appears on the order specs of many large industreal manufacturing & equipment companies around the world.
While I agree with Larry in regards to always carry a spare bearing and seals - learned that the hard way - I would be reluctant to give a full on approval of Chinese made bearings. The quality of made in China bearings varies GREATLY. Timken and SKF both have their bearings built in China these days. Yup its true ;-) but the difference in the bearings is the quality.
Only have to hold in one hand a bearing & seals made by Timken or SKF made in China and a bearing purchased off the internet made in China by a no name company selling for a 1/4 of the price of a Timken bearing to see and feel the difference.
While Dexter axles probable do come with China made bearings these days it is very probable they are not a no brand but instead made for Timken's or SKF.
Old 04-02-2014, 08:31 AM   #25
To Adjust Travel Trailer Brakes. Funny enough the first time I took the wheel & hub off my trailer it was clear looking at the brake pads that they were not adjusted correctly as they had very little wear on them even though they were almost 16 years old at the time. I had gotten a pretty good hint of that towing it home as I had to crank the controller *way up* in order to get the slightest hint of brakes on the trailer.
Dielectric Grease vs Electrical Contact Grease Roy in TO Problem Solving | Owners Helping Owners 28 09-16-2012 07:23 PM
UHaul Hubs...How to Grease Bearings? D Davis Towing, Hitching, Axles and Running Gear 3 07-17-2012 07:18 PM
grease type to use for bearings ThomasE Care and Feeding of Molded Fiberglass Trailers 16 08-30-2011 01:13 PM
To grease or not to grease? Keith Williams Care and Feeding of Molded Fiberglass Trailers 49 06-27-2009 04:52 PM
bearings and grease and antifreeze Chris Z Problem Solving | Owners Helping Owners 6 02-27-2006 06:52 AM
