how remove black water tank 82 Casita - Fiberglass RV
Old 05-29-2017, 07:26 PM   #1
Trailer: Scamp, Casita, Love Bug, Bigfoot
Im replacing the plywood in my sons Casita (1982) and I cant see an easy way to release the black water tank so I can remove it. Anyone have experience with this?? I removed the valve, but whats left doesnt want to budge.
roamingcamera is offline   Reply With Quote
Old 08-24-2017, 06:39 PM   #2
No Help?
I'm here looking for help also. Floor around my black tank drain is leaking. I can't use the toilet. The valve for the black tank was broke when I bought this thing and I think when it got hit, the black tank got broke. I'm going awaynext week. When I get back I'm going to start tearing the toilet apart. I'll get back to you then.
Fritz R. is offline   Reply With Quote
Old 08-24-2017, 09:41 PM   #3
Borrego Dave's Avatar
A phone call to Casita may give you an answer. Can't say I've read of anyone doing this on a Casita which may be why there were no reply's .
Old 08-24-2017, 11:07 PM   #4
Trailer: Trails West
I don't have a Casita but in my Sunrader bathroom the top section of the toilet drain flange screwed into the fitting that was underneath the fiberglass. It was not just stuck together with caulking, it was actually two pieces which threaded into each other. It might be worth a try turning the top section counter clockwise to see if it gives a bit. If it is threaded that would explain why you can't pry it apart from underneath.
Old 08-25-2017, 12:08 AM   #5
Different look
Interesting how your Casita has a step up. Mine has a tank you can see bolted into the floor. The screws that hold it down are covered in tons of caulk, but they're there. Yours look like it's molded into the egg. Like an integral part.
I never posted a picture here before. See how it goes.
Old 08-25-2017, 01:57 PM   #6
Another thread to check
http://www.fiberglassrv.com/forums/f...let-42276.html
casita
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
Draining black tank into grey tank..... Joe & Cherie General Chat 63 04-19-2017 06:35 PM
Easiest way to remove gray water tank. Aaronlux Modifications, Alterations and Updates 5 10-27-2014 07:05 PM
Replace or Remove the water tank? Kevin A Plumbing | Systems and Fixtures 13 04-10-2007 02:47 PM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
