How tight should this be? - Fiberglass RV
Old 05-30-2008, 01:02 PM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
How tight should the safety trailer latch bolt be? (See yellow arrow in photo)
I use a lock through the latch when driving to prevent the latch from coming loose.
Right now ,I have it set so I can just bring the trailer latch down and put the lock through the hole. With no forward or backward or side to side play on the trailer hitch ball.
Old 05-30-2008, 01:10 PM   #2
Dan Meyer's Avatar
Hi Kevin
You've got it about right. There is sometimes a spring between the nut and moveable jaw. If the nut is too tight the coupler will be hard to latch. Too loose, and you will have slop between the hitch and the ball.
-- Dan Meyer
Old 05-30-2008, 06:13 PM   #3
As Dan said, it looks like you have it right. Lowe's sells a white teflon based greese for the ball/hitch.
I always use the greese on our hitch.
Old 05-30-2008, 06:38 PM   #4
Trailer: Trillium 4500
I'm new to towing, 1 yr. Why the grease? how does this help? glad to see this link, my trillium 4500 is loose by this description, i'll look at it tomorrow and figure out how to snug it up...thanks
nick c is offline   Reply With Quote
Old 05-30-2008, 07:38 PM   #5
kevin61's Avatar
Trailer: 13 ft Boler and 17 ft Boler
Less friction with the grease. Therefore less wear on the ball. Your trailer can easily jump off of a worn ball.
kevin61 is offline   Reply With Quote
Old 05-30-2008, 09:52 PM   #6
Trailer: 1981 13 ft Scamp ('Dacha' Russian summer house) / 2006 Tacoma V6
Experts say that would take 375,000 years. But the black grease stain on your pant leg only 85 years. So wear shorts because skin is washable.
jim munson is offline   Reply With Quote
Old 05-31-2008, 08:39 AM   #7
I don't think you would wear out a ball however the parts of the hitch may be a different story.
I Completely clean the inside of the hitch and the ball then use the white grease. Not as messy as regular grease but still messy. I use a ball cover so I do not rub up against the messy ball.
I recalucated and think Jim was off a little, my calculations say it will take 375,995.0001 years.
Parking in a tight spot. Pat C Care and Feeding of Molded Fiberglass Trailers 5 08-20-2008 10:22 AM
Parking in a tight spot Bob Radenbaugh Problem Solving | Owners Helping Owners 19 11-23-2007 02:55 PM
Tight spot Greg Yother Care and Feeding of Molded Fiberglass Trailers 17 04-16-2007 06:30 AM
Tight Quarters in your 13' Egg? Frederick L. Simson General Chat 8 01-17-2007 07:44 PM
Tight Before Christmas Des Nolan Jokes, Stories & Tall Tales 1 12-14-2005 12:18 AM
