How to add flagpole holders for awning? - Fiberglass RV
Old 07-14-2019, 12:49 PM   #1
Trailer: 1974 Boler 1300
Hello handy people,
We own a 1974 boler, and would like to add flagpole holders under the side lights to hold our awning in place using the track. We would use a piece of 1/2 inch plywood to bolt each flagpole holder in place on the inside. Has anyone done this with a fiberglass RV? I've seen many photos of pup ups with this, but am not sure fiberglass would be strong enough, even with a large piece of wood on the inside.
Any other recommendations? Should we use silicone?
Sorry, my photos are all upside down.
Many thanks!!
boler girl is offline   Reply With Quote
Old 07-19-2019, 11:22 AM   #2
LarryB.'s Avatar
Trailer: Casita 17' Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
Bimini Fittings
My Casita has custom clip support points for awning support riveted directly onto the fiberglass and I donít think that there is any extra inside support. Unfortunately, the prior owner removed the awning after it was damaged beyond repair by a windstorm leaving the support points on the bottom/side and the roof mounted mounting brackets.
In lieu of the flagpole holders, I would think that bimini fittings normally used on boats might be better and less obtrusive. For example: support and frame. I suspect that there are different sizes which hopefully would fit your awning supports. They are also available in stainless steel.
And, yes, I would use silicone sealant when riviting/screwing the supports to your Bioler.
LarryB. is offline   Reply With Quote
Old 07-19-2019, 11:45 AM   #3
Thanks LarryB. I really like the Bimini fittings that you suggested, but we did the work a couple of days ago using the flagpole holders. I agree that they are more obtrusive than the Bimini, but they are white like our trailer, so not too much of an eyesore. We did use silicone and a piece a plywood inside. The mounts are hidden inside the back and front seats. We tested the awning yesterday in strong wind, and were very pleased with the results. We're going camping for 5 days next week, and will test it some more.
Again, thank you for taking the time to reply.
Old 07-19-2019, 12:43 PM   #4
The one thing that concerned me about you design is awning sag in the middle that could cause your brackets to twist. You could put a piece of PVC along the outer edge of the awning or place your stakes at an angle to keep the center of the awning tight.
Dave Fish is online now   Reply With Quote
Old 07-19-2019, 07:50 PM   #5
Thanks Dave Fish. We ended up adding a PVC pipe between the two poles using two "T" joints, and this lessened to the stress on the brackets greatly. Good thought.
awning
Scamp front window open holders.. Mcmarkrazz Modifications, Alterations and Updates 18 07-15-2019 08:56 PM
What fuses & holders for Solar system? Timber Wolf Electrical | Charging, Systems, Solar and Generators 4 07-17-2014 12:07 PM
TP holders tractors1 Modifications, Alterations and Updates 11 04-02-2013 08:07 PM
For Sale: Custom ABS (plastic) holders, drawers, rack liners tractors1 Parts: Buy | Sell | Trade 0 06-11-2012 06:11 PM
Stretchy Holders for Curtains Pam Garlow Problem Solving | Owners Helping Owners 11 08-03-2009 08:24 PM
