How to empty fresh water tank - Fiberglass RV
Old 05-18-2014, 05:18 PM   #1
Autin's Avatar
I have a 2005 Independence motorhome with the fresh water tank under the master bed in the rear of the bus. How do I empty the tank without removing it. I see 3 valves and when I pull them open, nothing drains.. However, if the water hose is hooked and on, that's the only time water will flow out of the valves. But tank isn't emptying.
Sent from my Galaxy Note 3
Autin is offline   Reply With Quote
Old 05-18-2014, 06:00 PM   #2
There is always a drain valve somewhere for the main water tank. It sounds like you are opening water line drains but...... you might try opening them again and also opening the filler to the water tank, it may be vacuum locked with the cap in place.
You might want to check into a Motorhome site for specific help. Most of us here are small molded fiberglass trailer owners/enthusiasts.
Old 05-18-2014, 06:04 PM   #3
Autin's Avatar
You're right. The filler cap was holding a vacuum lock. Thanks for the advice, it's draining now.
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
13CT Uhaul Fresh Water Tank Keith K Modifications, Alterations and Updates 2 03-26-2009 06:10 AM
can anyone out there tell me how you access the fresh water tank on a verna crowell Problem Solving | Owners Helping Owners 8 09-27-2008 06:03 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
Larger Fresh water Tank Ideas Steve Rosenberg Plumbing | Systems and Fixtures 8 12-15-2007 07:36 AM
