How to fix a scamp door - Fiberglass RV
Old 04-29-2011, 08:40 PM   #1
Mary Ann in MN's Avatar
Trailer: 1992 Scamp 13' Deluxe
How can one reform the door. Both the and the bottom have a large gap. I'm sure other have had the same problem, and would like to know how you fixed it. It's like the bow that is suppose to be in the door has straightened out. Adding more weather strip is not the answer. Both the top and the bottom have to be bent more so it will fit tighter against the camper to close the large gap.
Mary Ann in MN is offline   Reply With Quote
Old 04-29-2011, 08:42 PM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Are the hinges causing it? They are usually one of the first problems.
Old 04-29-2011, 08:44 PM   #3
The hinges are fine, and we also ordered and put that door hook on the bottom, but that didn't do anything to it.
Old 04-29-2011, 08:51 PM   #4
There are several different methods that can be used to fix the door. From hard (work), like this: Fiberglass RV - Document Center - Exterior
To a BIT easier: http://www.fiberglassrv.com/forums/f...ods-40235.html
To easiest still: wire and turnbuckles from top to bottom of the door to pull the ends closer together (I'll see if I can find a link later).
Old 04-30-2011, 12:53 PM   #5
Alf S.'s Avatar
Hi: Mary Ann in MN... I have a similar repair to do on my ''project'' Boler. I plan on making a cut out in the bottom inside panel of the door then cover it with a vent plate. Then I'll scoup out the wet swolen fiber board filling and install some bent 1'' square aluminum tubes in the bottom of the door liner and screw thru the inner door liner into the tubing. I'll use speed clips to screw the vent cover in place. I'll try to keep my digi cam. handy to record either my success or...whatever!!! Lastly I'll re seal the window with new rubber back seal and vinyl glass seal from Vintage Trailer Supply for the Hehr door window, which caused all the problems to start with!!!
Old 04-30-2011, 02:25 PM   #6
Here's FlyGal's solution to her 1977 Scamp door: http://www.fiberglassrv.com/forums/f...oor-41288.html
Old 05-06-2011, 02:06 PM   #7
Rick G's Avatar
Trailer: 74 Boler 13 ft / 97 Ford Aerostar
Smile
Here is my solution to the door curve problem for my Boler, the same basic design as the Scamp. It was pretty easy to do, looked good, permanent fix, worked great:
http://www.fiberglassrv.com/forums/f...tml#post173705
Rick G
Rick G is offline   Reply With Quote
Old 05-06-2011, 09:01 PM   #8
Robert J. was kind enough to send us some information on fixing the door. My husband took the door off. Took off all the old rat fur, hinges and the window. He made cuts in the fiberglass on the inside of the door, took a tiedown strap, and reformed the door. He than put new fiberglass on the entire inside of the door so it will hold it's new shape. When I got home today, he had all the new rat fur on, the hinges and the window back in it. Just have to hang it back on the camper. He did a beautiful job, and it looks just like a brand new door.
He's a Jack of all Trades and
I'm a Happy Camper
Mary Ann
Old 05-06-2011, 09:29 PM   #9
Greg H's Avatar
Indiana
With my luck the door will break.
Old 05-07-2011, 06:06 AM   #10
Robert Johan's information was provided above in my post. It's in the link... To a BIT easier:
Scamp door fix questions (recurve) LanM Problem Solving | Owners Helping Owners 0 08-01-2010 11:58 AM
Fix for door window leaks DannyH Problem Solving | Owners Helping Owners 2 12-10-2009 08:26 PM
Sagging Trillium Door Fix Joseph Olajos Problem Solving | Owners Helping Owners 4 07-12-2007 02:36 PM
how to fix door so it won't pop off kimberly Problem Solving | Owners Helping Owners 5 08-02-2006 10:40 AM
How do you fix a door? Windows? Legacy Posts Problem Solving | Owners Helping Owners 3 12-05-2002 06:45 AM
