How to get over ice? - Fiberglass RV
Old 02-09-2018, 10:26 AM   #1
Trailer: Casita SD17
New Jersey
I am iced in to an RV Park. There are some short steep hills covered in black ice (ice with water on top). My truck can get over the ice at 1mph, but I still slide on the hills. With my truck, I can aim for the rough patches at the edge of the road. With my trailer, I would not be able to do a crash landing. The area around my RV is all black ice.
I guess I will have to hire a commercial tow truck to move my Casita down the hills, so I can leave. I was going to buy some tire chains, but the seller said they would not help on ice. A guy with a bigger truck says his truck slides, too.
Any suggestions?
whoot is offline   Reply With Quote
Old 02-09-2018, 10:33 AM   #2
What you need is some sand and salt . How you are going to obtain it is another question
We keep two 30 gallon plastic trash cans full of sand and ice bite
at the edge of our driveway just for occasions such as yours.
Old 02-09-2018, 10:42 AM   #3
Raz
Raz's Avatar
Vermont
Any hardware store has bags of sand. Sprinkle on the ice and your traction will improve.
Old 02-09-2018, 10:50 AM   #4
Bruce H's Avatar
Trailer: Bigfoot 25 ft RQ
Where are you? If possible wait until it melts.
Old 02-09-2018, 10:51 AM   #5
If you have tire chains use them. If not go to a local tire store and buy some.
I have pulled my trailer through snow zones which in many state require carrying tire chains.
Old 02-09-2018, 10:56 AM   #6
You can also lay a piece of lathers mesh on the ice and then drive with the tires on the mesh . We carry a 5 or 6 ft piece in the winter for emergencies.
Old 02-09-2018, 10:59 AM   #7
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Maybe I don’t understand. If there is black ice all around you. Why would you even consider pulling your trailer? Risking damage to both trailer and truck.
Never the less being injured or injuring someone else.
Go figure!
Old 02-09-2018, 11:48 AM   #8
Hire someone that does plowing and sanding. Lots of people that plow driveways also have a small dump truck with a sander on it. There are even sanders that go on a pickup truck. Should be someone in your area that does this. I assume you just need to get out of the RV park to clear roads so they should take care of it.
Old 02-09-2018, 11:50 AM   #9
Raspy's Avatar
Trailer: Black Series HQ19, Oliver LE2
Smith Valley, Nevada
You don't say how far you have to go to get to clear pavement, but it seems pretty clear that you should wait it out if at all possible. Chains and salt will get you a short distance, but if you are facing a couple of miles, or very steep hills, it may be too much trouble.
Bob may have the best solution. Is the park willing to help? Or are others trying to get out too?
Raspy is online now   Reply With Quote
Old 02-09-2018, 11:56 AM   #10
I lived in the Midwest and have lots of experience driving in snow and ice. Driving in these conditions is an acquired skill. It would be best to wait until it melts. If you absolutely can't wait, chains on the tug and trailer would be the best option. If a chain breaks or loosens when running you could do some serious damage to your trailer. Best of luck.
Old 02-09-2018, 12:03 PM   #11
New Jersey
I have to leave because I have a new job waiting for me half-way across America, and each day I am stuck here, is another day they might change their mind.
I will buy some sand and salt and spread it around where my truck will pull from, and on the hills I have to go over. It's about 200 yrds of ice, but I am mostly concerned with 3 small hills.
It is going to get warmer Saturday and Sunday, so there might be enough melting that I can leave.
Old 02-09-2018, 12:10 PM   #12
New Jersey
There is a more experienced tow-er that also has to leave, he said he would help me this weekend. He is in a worse spot than me.
The park workers who are most experienced are not available right now, mostly just bad timing. They would pull me out with a tracked vehicle if they were here.
It is going to 45 degrees this weekend, so I will get out one way or another.
Old 02-09-2018, 12:21 PM   #13
mszabo's Avatar
I don’t think that is black ice. Most can’t see black ice until it’s too late.
I’d say that is a ice rink.
Good choice, be safe!
Old 02-09-2018, 12:42 PM   #14
Ice with water on top of it is more slippery than ice with no water on top. Ice gets less slippery when it's colder. Ice at 20 degrees below zero is much less slippery than ice at 30 above zero.
"Get Ready, Get Set" Mode Cathy P. General Chat 16 05-02-2013 09:59 AM
Ice ice baby - an alternative to traditional a/c or hocus pocus? glamourpets Modifications, Alterations and Updates 24 02-02-2013 09:38 AM
Ice Box - Where to find? Sandy Gilpin Care and Feeding of Molded Fiberglass Trailers 10 12-09-2005 10:26 PM
