how to glue reflextix - Fiberglass RV
Old 07-07-2012, 03:42 PM   #1
Trailer: 72 boler
Was wondering how you guys glue reflextix to the fiberglass?? and other stuff to the reflextix
Davidmulvaney is offline   Reply With Quote
Old 07-07-2012, 06:34 PM   #2
3M spray adhesive.
Old 07-07-2012, 06:43 PM   #3
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
And the good aluminum HVAC tape to join it to other pieces of Reflectrix or whatever suits your fancy
mmeyer is offline   Reply With Quote
Old 07-07-2012, 08:26 PM   #4
D Davis's Avatar
Trailer: Casita, previously u-haul ct13
Virginia
I used discount bathroom shower stall caulk. Worked great and still holding after a solid week of 100 degree temps.
D Davis is offline   Reply With Quote
Old 07-07-2012, 09:01 PM   #5
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
I was a firm believer in 3M 90, the stickiest retail product that they make. But I've learned from my local custom car interiors shop that the spray glues "re-activate" when heated. So insulation or fabric on a hot roof and/or walls could sag under certain conditions. The preferred solution? Good old' contact cement, properly applied and handled, of course.
Old 07-08-2012, 07:53 AM   #6
D White's Avatar
Trailer: Home Built
I agree here...and then we add perimeter construction glue with squiggles in the center, just before hanging. Takes good timing and maybe another set of hands, but we have had no failures to this point.
D White is offline   Reply With Quote
Old 07-08-2012, 09:41 AM   #7
Name: Norm I want to thank all the Kings horses and all the Kings men
Trailer: 73 Scamp 13'
Getting ready to tackle this as well. Can anyone recommend a brand/type/part number of contact cement that will withstand the high temps? I think I read on this forum that the water based type may work better than the others. I also think it was Robert J that said he painted the fiberglass first with an epoxy paint/primer. Not sure if that is necessary or not. We really appreciate all the suggestions. Norm and Kathrine.
Ngrimm is offline   Reply With Quote
Old 07-08-2012, 04:57 PM   #8
Sorry, can't speak to the efficacy of the water-based cement. I'm now using the standard oil-based Dap/Weldwood product, again based upon the recommendation of my interiors guy.
I don't think painting the inner shell is necessary, if you have a good, clean and smooth surface with which to work. Frankly, I paint mine first to help me locate any possible problem areas, and to seal any really raw areas of fiberglass where aggressive sanding, et al, may have been required to get the old crap out of the way.
boler
wood to fiberglass glue? Gardner Problem Solving | Owners Helping Owners 15 04-26-2012 10:44 PM
Carpet glue Gene Masse Problem Solving | Owners Helping Owners 2 01-21-2012 06:20 PM
How to glue ensolite back on Barry Konkin Problem Solving | Owners Helping Owners 10 02-02-2009 02:59 PM
removing glue colleenz Problem Solving | Owners Helping Owners 11 10-05-2007 08:03 AM
spray glue trouble JIMZ Problem Solving | Owners Helping Owners 7 05-25-2006 10:49 AM
