How to hold down the propane tank - Fiberglass RV
Old 12-02-2008, 08:40 PM   #1
lizandjola's Avatar
Trailer: 1974 Trillium 13 ft
Hi folks. We have removed the scary old bungee cords that held down the battery and propane tank on our Trillium's tongue shelf. The battery is now nicely contained and bolted down in a lovely new weather proof box. Whew. The propane tank is held on with a couple of tie-downs at the moment and this does not make me happy. I have seen metal thingys that tighten and hold the tank in place and a few photos of cages that hold the tank. Where on earth do I find such lovely devices? I don't even know what to call them and the auto parts store fellows want to sell me more bungees. Yikes.
Thanks for your help!
lizandjola is offline   Reply With Quote
Old 12-02-2008, 08:55 PM   #2
You could probably fashion it yourself. The Rona hardware store near me sells threaded rods about 3 feet long. You get one or two of those as required. Bend to hook onto the tank or through the top of the tank. Then you'll need a metal strap. I think you can find that too. A couple washers and bolts, or better yet, wing nuts. You mention a shelf, and I'm not familiar with your set up, but you could probably drill a couple holes in it for the threaded rod instead of investing in a metal strap.
BTW, bungee cords tend to rot and let loose at the worst moment.
baglo
Old 12-02-2008, 09:05 PM   #3
Roger C H's Avatar
Talking
Are you talking about turnbuckles?
http://www.grainger.com/Grainger/items/1WBR6
Old 12-02-2008, 09:10 PM   #4
Orlen Wolf's Avatar
I think the item you are looking for is a "single LP gas bottle rack." It consists of a vertical metal strap with a metal band around the tank. There are other mounting methods available such as straps that clip over the tank and several mounts for double tanks. If I remember correctly you have a single tank so the dual tank systems won't work for you.
A neat source for an on-line catalog of RV accessories is the Ketelsen RV web site, www.wegocamping.com. Their illustrated color catalog is great for browsing to see what's available (I think it's about 600 pages). They have just about anything you can imagine for any type of RV. If nothing else it will give you a picture and the "proper name" of what you are looking for so you can search for a similar item in your local area and ask for it by name.
I'm lucky that Ketelsen RV is about 5 miles down the road from where I live (Denver CO area). I can just jump in the car and drive right down there. They also have a place somewhere in Iowa.
Orlen Wolf is offline   Reply With Quote
Old 12-02-2008, 09:40 PM   #5
Chester Taje's Avatar
On a Compact J which i have since sold i had my tank fitted in my spare tire on the front. I also had the tie downs which have been described. Here is a picture.You can do this with or with out tire. You should see brackets clearly.
Old 12-02-2008, 09:43 PM   #6
james kent's Avatar
Trailer: Boler 1984
Here's a picture of the hold-down for our propane tank that came with the trailer. It consists of an upper strap, on each side, that hooks over the tank and a threaded rod. When tightened down that tank doesn't move or even quiver. The battery box was used as a tool box for pliers, screwdrivers, hammer and wrenches, etc. We have since added a larger box with a class 27 battery and use a ratchet strap to keep it in place.
Wondering now where to mount the old box. Hmmm?
Old 12-02-2008, 11:46 PM   #7
Attachment 17034
James' picture shows what I have in mind. The threaded rods I've seen are 1/4 or 3/8 inch by about three feet. I have no idea what purpose they serve as sold, but bent to the right shape, they would work just as James' straps. Of course, if you can get James' straps, you can save a lot of messing about, and it could even be cheaper.
I had the same set up on my tent trailer. Whatever you do, make sure you replace the stupid little nuts with large wing nuts and liberal doses of WD-40 so you can get the tank off easily for refill.
baglo
Old 12-03-2008, 12:59 AM   #8
MikeCM's Avatar
Trailer: Actively shopping for a project, again.
I would check out one of these racks from rvsurplussalvage.com. Dual lp rack
Mike
Former 83 Burro Owner (destroyed in fire)
Looking for a new Fiberglass Project Trailer in New England.
MikeCM is offline   Reply With Quote
Old 12-03-2008, 10:38 AM   #9
james kent's Avatar
Trailer: Boler 1984
Hi Glenn
I have, in the past, purchased the threaded rod and the strapping, for other projects, at Canadian Tire, so I would imagine that it is also available at most hardware stores. Possibly at a Lowes or Home Depot as well. Replacing the nut with a wing nut is sound advice as it's a b^&* to twist that thing down with a wrench.
Old 12-03-2008, 01:24 PM   #10
April Wilcox's Avatar
Trailer: 13 ft Scamp 1983
I have been searching the web for those single tank straps, and this is what I have found so far... not sure if this will work for your needs, but it might be a good solution.
http://www.tjtrailers.com/store/single-lp-...ottle-rack.html
here is another link for the same product, only they use a real picture...scroll down
http://www.rvadenver.com/lp_gas_accessories.htm
I can not seem to find the straps that bolt down anywhere online, they must have a specific name that I haven't been able to figure out yet. They seem to be a fairly common method to secure a tank, so there must be a source out there somewhere.
April Wilcox is offline   Reply With Quote
Old 12-03-2008, 05:26 PM   #11
Pete Dumbleton's Avatar
Call Scamp parts and ask about theirs -- Similar to Boler above except the metal straps go all the way down to the bottom and attach with nut and bolt.
Old 12-04-2008, 07:09 AM   #12
james kent's Avatar
Trailer: Boler 1984
Since the straps seem to be different for different trailers, they were probably manufactured on site. Shouldn't be too difficult to do. About 120 degree bend at the top and a 90 degree bend at the bottom. If you don't have a vice on your workbench then clamp them between two boards and hammer them. Make them slightly shorter than your tank and the bolt will pull them down tight.
Old 12-04-2008, 08:22 AM   #13
Good advice James, but I wonder what metal is the best to use for the strap so it doesn't bend too easily. Our trailer has them already, so it is a non issue for us, but in case other's try to make their own after reading this thread, I feel it's important to be sure the proper materials are being used for safety.
Old 12-04-2008, 12:57 PM   #14
Another way would be to use Bob's turnbuckle above with some chain and S-hooks. Get it as tight as you want! Cost more, however.
propane
20 lb. Propane Tank Exchange George Cathcart General Chat 17 06-24-2014 12:51 PM
Propane fridge won't stay lit after the minute hold down Karalyn Problem Solving | Owners Helping Owners 5 06-24-2009 12:19 AM
PROPANE TANK JIM DUNNE Problem Solving | Owners Helping Owners 5 05-17-2009 07:19 PM
Propane Tank hold-down EricMeyer Problem Solving | Owners Helping Owners 15 04-18-2007 11:56 PM
Old Propane Tank Cover playared Classified Archives 0 01-21-2006 09:24 AM
