How to patch area where bunk bed hinge was removed. And suggestions on cooker placeme - Fiberglass RV
Old 05-31-2015, 06:55 AM   #1
Newbie's Avatar
Name: Jeff short for Jennifer
Trailer: 13 ft Scamp 1977
Name:	ImageUploadedByFiberglass RV1433076223.433535.jpg
We are reconfiguring our 1977 scamp. The top bunk has been removed and there is an ugly area left behind. See picture. Good husband will dremel this down, but we are not sure how to patch it. Right below this will be the Formica counter top. (BTW, Placing Formica on the plywood was way easier than we thought)
Also, we are having trouble deciding where to place our two burner cooker. Straight across, catty corner, back to front. It might not matter that much, but I'm betting as soon as that hole gets cut we are going to realize we made a logistical error. So would appreciate thought here.
Newbie is offline   Reply With Quote
Old 05-31-2015, 07:00 AM   #2
Newbie's Avatar
Name:   ImageUploadedByFiberglass RV1433077065.815787.jpg
Name:   ImageUploadedByFiberglass RV1433077095.949079.jpg
Name:   ImageUploadedByFiberglass RV1433077135.583244.jpg
Name:   ImageUploadedByFiberglass RV1433077152.769242.jpg
Oops ,pictures did not download as intended...thanks for patience
Old 05-31-2015, 10:52 AM   #3
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
If the older Scamp ensolite wall coverings is the same as that used in the Trilliums I have found that DAP almond acrylic caulk matches quite well to fill screw holes and minor imperfections. It can even be textured a bit to match the elephant skin texture.YMMV
Reid Larsen is offline   Reply With Quote
Just got a 94 Samp 13 with top bunk removed... CarltonC. General Chat 5 05-31-2015 12:04 PM
Trillium door hinge fix, need inside patch Colleeno Problem Solving | Owners Helping Owners 4 10-10-2014 12:22 PM
Leak in Fan area, Air Condition Removed, Door Sealant Seeitall Problem Solving | Owners Helping Owners 3 05-20-2013 06:44 PM
CT-13 Main Bunk bed hinge dimensions djtriceflt Problem Solving | Owners Helping Owners 20 11-09-2011 08:49 AM
Should I just remove the vent and patch the hole? Amy M Problem Solving | Owners Helping Owners 0 01-10-2010 06:25 PM
