how to put down jacks in the back of Scamp - Fiberglass RV
Old 07-19-2008, 06:29 PM   #1
Trailer: 2008 16 ft Scamp
Can someone please tell me how to put the jacks down in the back of my Scamp?
I thought I had this figured out. I have done it once. You push the jack in toward the Scamp and pull the jack down. There must be more to it because I have tried and tried.
Thanks for any help on this.
Doris
Doris is offline   Reply With Quote
Old 07-20-2008, 06:21 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
If they are swing down jacks it should be pull out away from the mount and then rotate down. then pull down the extension. reverse order to put them back up.
Joe
Old 07-20-2008, 08:16 AM   #3
Hi. Thanks for the help. I have done the first step by pushing the jack in toward the trailer but I can't pull the jack down. I must be missing somethin. This is a brand new 2008 Scamp so the jack should be working fine.
Old 07-20-2008, 10:17 PM   #4
paulw's Avatar
Trailer: 2009 Escape 17 ft
Hi Doris,
The "Choosing a Camp Site" video on the Scamp web page show it being done.
Scamp videos
Paul & Norma
2005 Hunter Fat Shadow, 1995 Scamp 16, 2009 Escape 17B, 2013 Escape 21
2022 Coachmen Nova 20C
paulw is offline   Reply With Quote
Old 07-21-2008, 11:28 AM   #5
In a damp climate they have a tendency to rust quite rapidly and get stiff. I have to remove mine from the bumper, clean and greased them within a couple months of new. Once done they work quite well. It's been over two years and they're still very workable.
To deploy them pull towards the center of the trailer until they release. Once in the down position push down on the lever that towards the outside of the trailer. The foot should drop to the ground.
I don't like the video because I see no need to jack the trailer with them. It looks to me like a good way to tweak the frame.
I think the best way to set up and level the trailer is as follows;
First level the trailer side to side with either blocks under the wheels or using a BAL leveler, (BAL leveler my preference).
If you're not using a BAL leveler then make sure you chock the wheels, then unhitch.
Once unhitched lower the front the trailer with the tongue jack to somewhere between 1/2 bubble and 1 bubble off level with tongue low. (NOTE: Will need some kind of level for this process)
Deploy the rear stabilizers with the feet against the ground or blocks.
Raise the tongue with tongue jack to level.
All done, no fussing with jacking bar on the stabilizers, no tweaking of the frame.
Byron
Scamp Back Leg is Broken Mark J Problem Solving | Owners Helping Owners 13 11-07-2009 08:08 AM
Scamp rear leveling Jacks length? Roger Harshaw Towing, Hitching, Axles and Running Gear 2 04-20-2009 02:23 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
Installing a Scamp Door Hold Back efawcett Problem Solving | Owners Helping Owners 4 08-02-2007 07:59 AM
Just Got Back From Scamp Factory John Kellow General Chat 12 03-07-2007 08:07 PM
