How to release wires from blue plastic restraint on power converter - Fiberglass RV
Old 06-27-2010, 12:06 PM   #1
Trailer: 1990 Bigfoot 5th Wheel
I am replacing the shore power hatch. Since the molded plug will not fit through the external hatch, you have to disconnect the 120 external cord from the other end, at the power converter. I have the green, black and white wires free, however, the cord is restrained where it enters the converter by a blue plastic collar; and very firmly, at that. How do I release the wires from the blue collar? This set-up is behind a small hatch and I can't get at it all that well. Please and thank you.
Cam
Old 06-27-2010, 05:22 PM   #2
FRANK MOLIS's Avatar
Trailer: 1980 (Circa) 13 ft Scamp (A WORK IN PROGRESS)
Its probably in a strain relief (pictured) and you have to pop it open (maybe with a screwdriver) to release the wire.
FRANK MOLIS is offline   Reply With Quote
Old 06-27-2010, 05:48 PM   #3
Thanks, Frank, I got it. It turns out it is a CSA-approved plastic push-in strain relief. Two little clips from the converter side and it pushes back out. Couldn't find a method to make it release the wire (one way ridges). I will replace it with a standard metal house panel clip.
Old 06-27-2010, 07:24 PM   #4
Glad you got it.
Frank
Old 06-27-2010, 08:54 PM   #5
So... the CSA still gets a little respect. Even after reconstruction and all the obfuscation?[lol]
Old 06-28-2010, 11:07 PM   #6
Trailer: Burro 13 ft
they're called Heyco fittings and are designed to be clamped together with a special tool. Usually a carefully aligned, needle nose or channel lock can be used to pinch the two sides together enough to pull the fitting through the hole. I have used these a fair amount on custom lighting fixtures.
kyle minor is offline   Reply With Quote
Anyone try this power converter DannyH Problem Solving | Owners Helping Owners 13 12-04-2009 12:56 PM
Power Converter & Breaker Box $60 kentj Classified Archives 2 04-28-2008 10:51 PM
Power Converter Chester Taje Problem Solving | Owners Helping Owners 14 08-10-2007 10:24 AM
Power Converter gerry gregory Problem Solving | Owners Helping Owners 7 08-31-2006 11:18 PM
Power Converter Legacy Posts Problem Solving | Owners Helping Owners 3 05-25-2003 07:02 PM
» Trailer Showcase
Casita
GlendaW
Swanky
Donna R
