How to remove Dometic RM24 from Trillium 1300? - Fiberglass RV
Old 04-12-2015, 06:15 PM   #1
Thought I'd ask before getting into this. After disconnecting the gas line and wiring, what's holding it in? We're upgrading to an Engel or Nova Kool, depending on space.
ajdemo76 is offline   Reply With Quote
Old 04-12-2015, 07:23 PM   #2
Ian G.'s Avatar
A quick Google search will provide your answer
http://www.dometic.com/QBank/EPiServ....036_17707.pdf
Old 04-12-2015, 07:28 PM   #3
Thanks Ian. Couldn't find anything like this earlier myself. "Domestic fridge removal" doesn't bring up much!
Old 04-13-2015, 08:42 AM   #4
David Tilston's Avatar
Does the RM24 work? What are you going to do with it?
Old 04-13-2015, 09:25 AM   #5
Just for a quick note, I looked at the installation manual on my Dometic 2193. There's a couple of L brackets installed on each side. These appear to butt up against the inside of the cabinet. Then for final, there's a couple of small bar brackets that attach at the top and bottom of the fridge from the OUTSIDE of the cabinet. Dunno if this will help much but that appears to be the basics of my installation. Both of these mounts I speak up would be at the front of my fridge.
Old 04-13-2015, 11:18 AM   #6
Thanks for the heads up Darral. I'm expecting this to be somewhat of a pain to do.
David. We will be getting rid of it. Not sure of the value of it if any without doing some research. It works great off 110, propane doesn't work well (maybe needs cleaned out) and it won't work off 12v. The door seal was spray painted by a previous owner so we replaced that with closed cell door seal. Didn't want to put $70 into something we planned on replacing ASAP. I'll post some photos of it on this forum once I get it out and cleaned up a bit.
Old 04-13-2015, 07:22 PM   #7
Name:	ImageUploadedByFiberglass RV1428974396.485743.jpg
ID:	82586Click image for larger version
Name:	ImageUploadedByFiberglass RV1428974419.289027.jpg
ID:	82587Click image for larger version
Name:	ImageUploadedByFiberglass RV1428974436.705904.jpg
Got it out! Two screws up front were really all that was holding this in place. Looks like there was an electrical fire at one point and this fridge may have been a replacement. Either way, time to figure out what to replace it with and clean up this wiring and gas line.
Old 04-14-2015, 05:45 PM   #8
No freezer door, or shelves? No wonder you want a new one.
The fact that it works on 110vac means it works. If someone has one that doesn't work, they could transfer any parts required from their old one. Were you closer, I would be interested.
Old 04-14-2015, 06:28 PM   #9
There are shelves, just not in the picture. Yea, maybe someone with another one would want to combine parts to make one good one.
Old 04-14-2015, 07:34 PM   #10
Trailer: Perris pacer
Hello AJ ! I'm looking for some parts for my dometic ! Need the unit that controls the ac/DC lp gas knob ! I broke mine and need to fix it ! Let me know if u have that part ? Thks Bob
mexbob5150 is offline   Reply With Quote
Old 04-15-2015, 08:27 PM   #11
You mean this? Click image for larger version
Name:	ImageUploadedByFiberglass RV1429151270.788341.jpg
Old 04-15-2015, 10:34 PM   #12
Bingo ! That's it ! How much do u want for it ? Call or text me @ 805-469-9456 ! Thks
Old 04-15-2015, 10:36 PM   #13
Looks like it ! I'll tak a look tomorrow ! And tak a pix ! �� Thks
trillium
CANADA - Trillium 1300 - $1300 David Tilston Referrals: Molded Fiberglass Trailers 2 01-26-2016 12:34 PM
How to remove and reinstall the "bubble" windows (Trillium 1300) coalminecanary Modifications, Alterations and Updates 13 10-05-2013 10:25 AM
How do I remove the body from the frame? 1971 Trillium 1300 coalminecanary Modifications, Alterations and Updates 26 06-11-2012 09:41 AM
Dometic RM24-Burner lights but doesn't stay on. Steven Potter Problem Solving | Owners Helping Owners 11 06-25-2011 03:01 PM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
