how to replace wall supports on a scamp - Fiberglass RV
Old 06-08-2014, 06:36 PM   #1
Arkansas
Bought a 1982 13' scamp and the floor and wall braces for the benches are rotted and need replaced any ideas on the best way to replace these will be greatful. No clue how to even start to replace these parts. Help anyone
mojowheeler is offline   Reply With Quote
Old 06-08-2014, 07:22 PM   #2
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
The bench wall supports are rotted? Yikes - sounds like they - and the floor - must have gotten wet.
To replace the wall supports I recommend this:
- Remove the old ones. With a hand chisel or sharp edged putty knife carefully pry them off.
- Cut new supporting tabs from plywood - not particle board (!!!). If possible, use the original tabs as a template. If they are not usable, then make templates out of cardboard, adjusting the shape by trial and error until you get it pretty close.
- Clean the side wall where the tabs attached, removing all traces of old wood, adhesive, insulation, etc. Use coarse sandpaper, a wire brush, or even a chisel if necessary.
- Wash the area with soap and water and than rub it down with acetone (follow the precautions on the acetone label)
- Buy some decent quality epoxy and mix it up. Using a brush, cover the wall area with a nice thick coat of the epoxy. Do the same with the tabs. Press them into pace. Use plastic tubs or buckets cut to the right height and shape (or some other creative way) to make sure the tabs stay where you want them to be. Do this before you start with the epoxy. Dribble the epoxy mix into any and all gaps between the wall and the tabs. Don't worry about the plastic, the epoxy will not stick to it.
--- An alternate to the epoxy is a good quality polyurethane adhesive, such as Loctite PL Premium Construction Adhesive. (I do NOT recommend Liquid Nails for this application). If you go this route you need to make sure that the tabs are firmly pressed up against the side walls while the adhesive cures. You could cut a couple 2x4s to length and wedge them across the trailer, pinning the tabs in place. All other steps remain the same.
The floor is a whole other issue. The rotted sections need to be removed. If the rot does not extend beyond the base of the benches you could just cut replacement panels and glue them over the remaining parts of the floor in that area. Give it all a coat or two of oil based paint - top and bottom - after the glue dries. You'll want to completely seal up any exposed original flooring or it will just suck up moisture like a sponge.
If the rotted flooring extends beyond the benches you have a bigger project - but the basics remain the same. You'll remove the rotted material and piece in a plywood replacement.
If you get stuck - post some pictures of what you have after you get the rotted stuff removed and you'll get some suggestions from others who've been down the same road.
Good luck. I think this is a pretty common adventure for anyone with a previously owned Scamp.
Oh yeah - try to determine how things got so wet to begin with. Maybe the windows were left open in the rain - or maybe there are leaks. You might hose the whole thing down and then look for any leaks.
Steve_N_Janna is offline   Reply With Quote
Old 06-08-2014, 08:40 PM   #3
Roy in TO's Avatar
[QUOTE=Steve_N_Janna;463441]The bench wall supports are rotted?
QUOTE]
Since the benches will be out already, they can be used to make a good template. They will have the same curvatures at the same wall height, they will be a little shorter on either end.
Old 06-08-2014, 08:57 PM   #4
Trailer: 2014 Escape 21, Lil Joe
Mike
Go with Steve's and Roy's instructions. I use West System Six 10 Epoxy adhesive filler to attach the seat brackets and floor to the shell then glass in the the pieces with epoxy resin. The two parts of Six 10 are mixed in the tube tip. So buy extra tube tips if you plan on using the tube of Six 10 more than once.
Eddie
Old 06-08-2014, 09:39 PM   #5
Arkansas
Ill try to get everything removed off the walls and use yall's suggestions. I think yall know what im up against. Thanks for the info so far ill keep you posted
Old 06-09-2014, 08:35 AM   #6
Roy in TO's Avatar
If the plywood has only separated, I fixed one of mine with wood glue and clamps.
Improving door fit due to body sag
Old 06-09-2014, 10:01 PM   #7
Arkansas
No its rotted amost to nothing very little left at all. I am just hoping i can get them back to close to where they were without a whole lot of problems. Making them i dont think ill have any trouble cause i can use the bench curve to make the curved wood but getting them to stay glued or fiberglassed to the wall is my main concern.
To Replace Or To Not Replace??? Susan Landis Modifications, Alterations and Updates 11 07-29-2011 09:19 AM
Bunk Supports in Scamp 13 barryra Problem Solving | Owners Helping Owners 7 08-13-2010 12:59 AM
Scamp stone guard supports? Nick Glenney Modifications, Alterations and Updates 7 04-20-2009 04:50 AM
Scamp Trailer upper cabinet metal supports... Lynn L Problem Solving | Owners Helping Owners 6 06-29-2008 10:20 AM
