How to seal roof vents properly - Fiberglass RV
Old 05-30-2011, 09:40 PM   #1
Trailer: Big Foot camper
Hello everyone,
I tried to find the answer here, but ....not being very good with the pc.....I gave up
But I need help. The seal/caulking/whatever around our roof vent is cracking and it looks like it needs to be redone.
Do I have to remove all the old stuff?
What do I use to seal the roof vent???
Thanks for helping
Petra
mountain is offline   Reply With Quote
Old 05-30-2011, 10:08 PM   #2
Trailer: 78 13' Scamp
I had the same question. I found this thread helpful. I'm going to use Stainless Steel fasteners as member Con suggests.
Butyl Tape, Silicone and sealing
koehlerk is offline   Reply With Quote
Old 05-31-2011, 03:40 PM   #3
Thanks, that thread was very helpful.
I am still wondering though, if I have to remove all the old caulking down to the fiberglas or......????
Old 05-31-2011, 04:06 PM   #4
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Yes.
Old 05-31-2011, 08:37 PM   #5
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
When I replaced our roof vent I cleaned all the old sealant and wiped the fiberglass w/ acetone to get a clean surface, then put a layer of butyl tape on the vent and screwed it in place w/ ss screws and washers and nuts inside, pulling the vent tight to the fiberglass body. Then I cleaned the squish out of putty and sealed over the top of the joint and over all the fasteners with Dicor lap sealant. No leaks and we have had a wet Oregon spring that certainly tested the seal.
Good luck!
Reid Larsen is offline   Reply With Quote
Old 06-02-2011, 01:54 PM   #6
Trailer: 1977 Boler
The old caulk should come off easily with a putty knife (or spatula) and a rag with Varsol or something similar. Rub it down to the bare gelcoat and you'll get a proper seal when new caulk is applied.
Mark V. is offline   Reply With Quote
Oversized roof vents Escape hatche pjanits Care and Feeding of Molded Fiberglass Trailers 1 09-23-2008 09:44 AM
Sheesh! roof vents... Lynn L Care and Feeding of Molded Fiberglass Trailers 7 07-13-2008 08:56 PM
OEM metal roof vents Scott S. General Chat 3 06-25-2008 06:00 PM
Failing roof vent seal Tony Nowak Problem Solving | Owners Helping Owners 1 05-21-2008 08:47 AM
