How to Seal Windows to lil Bigfoot - Fiberglass RV
Old 10-04-2008, 11:48 PM   #1
Trailer: Lil Bigfoot 13 ft 1989
I am fixing up a Lil Bigfoot 13Ft 1989. All the windows have been removed, cleaned, and replaced with butyl tape and silcone seal at the seal between frame and fiberglass. This worked great, a very good seal.
Unfortunately, there is a leak between the rubber gasket/frame and the plastic polycarbonate sheet on the front window.
There is a sealant used between the plastic and the frame/rubber gasket.
Does anyone know or have a suggestion on what to use?
Craig CC is offline   Reply With Quote
Old 10-09-2008, 08:46 PM   #2
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
I have sealed them up at the shop where I work and if you have 3 mil (1/8) polycarbonate windows do not use silicone....
Use a butyl or polyurethane based selant like Dymonic. Run a small bead between the polycarbonate and the frame and them
push in the rubber glazing gasket to hold everything in place.
Doug P. is offline   Reply With Quote
bigfoot, windows
Bigfoot windows stevebgrassvalley Care and Feeding of Molded Fiberglass Trailers 8 07-24-2015 09:39 PM
Need To Seal on Bigfoot? Ron N Care and Feeding of Molded Fiberglass Trailers 17 05-07-2015 04:08 PM
Will Scamp windows fit in a Lil Bigfoot??? Jeff Segel Problem Solving | Owners Helping Owners 1 07-20-2009 02:13 PM
What's the best caulk to seal windows?? Mary Lynn K. Problem Solving | Owners Helping Owners 9 04-22-2009 09:03 AM
window seal/insert for louver type windows Legacy Posts Problem Solving | Owners Helping Owners 1 10-17-2002 05:15 PM
