How to Strip Poli-Glow? - Fiberglass RV
Old 03-02-2011, 07:16 AM   #1
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Working on the exterior of our newly aquired 2003 Casita 17SD.
The previous owner used "Poly Glow" on the fiberglass.
He gave me his remaining supply of it along with their product for preping before new applications "Poly Prep". The cleaner is supposed to remove all waxes, dirt and the old Ploy Prep.
I wanted to remove all the Poly Glow and use a good boat wax, but so far, it isn't happening. Any ideas?
Has anyone used or is now using Poly Glow?
Thanks,
Kip
Kip in Ga. is offline   Reply With Quote
Old 03-02-2011, 08:30 AM   #2
Matt in SV's Avatar
They make gel and aerosol strippers. Online, on the boat forums, some suggest ammonia solutions would work and others say no. One guy claimed success with poli prep, which is what I believe you had. Here are some poli strip instructions:
How to Remove Poli Glow | eHow.com
You should be able to find the poli-strip here
Welcome to Poliglow Products - The Manufacturer for Over 15 Years!
I can't suggest using floor Red Maxx floor stripper, but maybe someone's tried it?
Regards,
Matt
P.s. There are some similar threads below with the names of folks you might ping about this.
Planning our next Escape!
Old 03-02-2011, 03:44 PM   #3
Mike Magee's Avatar
Trailer: Li'l Hauley
Kip, obviously you are not lazy like me. I would just wait until age and weather took it off for me. Hopefully someone here has tried removing that stuff by now and can advise you. My only advice would be, try not to work too hard at it!
How to prepare Tofu
Step 2: grill some meat
Old 03-02-2011, 06:45 PM   #4
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
that poly prep is pretty rugged stuff....are you sure that isnt removing enough of the old poliglo?
Bruce Thomas is offline   Reply With Quote
Old 03-03-2011, 06:03 AM   #5
Kip in Ga.'s Avatar
Thanks guys/gals. The Poly Prep just isn't getting the job done.
The links you sent will work. Going to order the striper from Poli Glow.
Problem is that when it was sealed by the previous owner(s) the gelcoat wasn't totally clean. There are stains under the Poli Glow that I need to get to and hopefully remove.
Might just strip the old off and apply new Poli Glow. As the camper is under cover most of the time, a good application of Poli Glow just might
last longer than the 12 months they speak of.
Old 03-21-2011, 06:39 AM   #6
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
You might want to try the REDMAX Stripper it's a LOT cheaper and works great also..I had put Poli-Glow on one of my campers and REDMAX floor finish on the other 2 that I have to see the difference.. Then later I bought some new TRILLIUM 4500 decals and had to strip the poli-glow before applying the decals, so I tried the REDMAX stripper and it worked better that the Poli Prep that came with the Poli-glow package...I'd go for REDMAX Floor Finish if you are going to put it back on a gal. is only $15.00 and it is just as good..I know because I've used both and the Redmax looks better than the POLIGLOW in my opion.. went yesterday to HOME DEPOT and ZEP now has a new one called WET LOOK FLOOR FINISH commercial grade. I'm in the process of redoing my 4th Trillium and I'm going to try it out on it when I start putting it back together.....
Randy Bishop is offline   Reply With Quote
Old 03-21-2011, 07:26 AM   #7
Kip in Ga.'s Avatar
Thanks Randy,
Do the strippers have any negative effects on decals, like fading them or removing them?
Kip
Old 03-21-2011, 07:31 AM   #8
Wonder if good ole stinky ammonia would work? It's cheap enough if you can handle the fumes. The lemon scented is a bit more tolerable. I'd make sure there's plenty of ventilation tho...
Old 03-21-2011, 07:53 AM   #9
Kip in Ga.'s Avatar
Hey Donna,
That's a thought!
Might try ammonia in a hidden spot like between the hot water heater and battery compartment. Concerned about applying anything that might cause a chemical reaction that would affect the surface of the gelcoat.
Kip
Old 03-21-2011, 01:33 PM   #10
Kip, I think ammonia was one of the strippers mentioned in the RedMax topic. If you do try it, wear gloves!
Old 03-21-2011, 03:17 PM   #11
Ardmore, Alabama
The RedMax Stripper is only $8 a gallon i don't think ammonia can be much cheaper than that.................
Old 03-21-2011, 07:09 PM   #12
How about eight gallons for $8 total at Dollar Tree: Totally Awesome Pure Ammonia
Old 03-21-2011, 07:42 PM   #13
Ardmore, Alabama
What can I say Donna you out did me on this one
Old 03-21-2011, 07:43 PM   #14
I love the dollar stores. If I screw up at least it doesn't cost me much
Anyone tried Poli-glow? Jeanne and Steve Care and Feeding of Molded Fiberglass Trailers 67 01-16-2012 06:08 PM
Poli Glow & Gelcoat Question Bruce Thomas Problem Solving | Owners Helping Owners 10 04-09-2010 04:11 AM
Poli-Glow over Decals? Pamela S. Problem Solving | Owners Helping Owners 2 04-04-2010 07:13 AM
PoliGlow in Canada? Paul Richter Problem Solving | Owners Helping Owners 12 05-07-2009 10:34 PM
Poli-glo Questions re application Bobbie Mayer Problem Solving | Owners Helping Owners 5 07-29-2008 10:17 AM
