How to tell axle size? - Fiberglass RV
Old 05-02-2012, 01:16 AM   #1
David Swinnard's Avatar
Trailer: Had to sell, no longer an egg owner
I have a '76 Trillium 13 footer and the other day I pulled the hubs off to check the bearings and the grease. I checked the numbers of the bearings and today found the paper the PO had written the bearing/seal numbers on (confirming what my aging eyes read...). After checking a number of internet sources for the bearings it seems to me the numbers I'm dealing with are related to the Dexter 3500# axles.
I just assumed the trailer (don't ask me why) had a 2000# or so axle, not a 3500# one. The internet sources suggested the "smaller" axle has a different bearing set than I've got.
So, is there a way I can know for sure what rating axle I've got?
(I don't have brakes and am researching those options. It seems the 2000# axles use a smaller 7" brake while the 3500# uses a 10" brake. If I need 10" brakes then the question of whether my 13" wheels will take the larger diameter brake drum arises...)
David Swinnard is offline   Reply With Quote
Old 05-02-2012, 06:06 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
When I added brakes to my UHaul CT, I used the 3500# spindles and 10" brakes. The brake drums just squeak into the 13" wheels.
I believe that rubber torsion axles can be custom ordered at different weight capacities by changing the rubber inserts. So the spindles may be rated at a higher capacity than the suspension.
Hopefully someone more knowledgeable will jump in here on this last point.
Old 05-02-2012, 08:53 AM   #3
IllAnnoy
On a 2200# or smaller Dexter axle the spindle is straight.Either 1" or 1-1/16". The next larger axles, up to 3500#, have tapered or stepped spindles with the inboard bearing being larger than the outboard bearing.
When new, Dexter axles have an info sticker on the axle tube.
The smaller axle (straight spindle)will only accept 7" brakes, while the larger one takes 10" brakes.
Old 05-02-2012, 09:54 AM   #4
Mine is not a Dexter, but has a metal tag riveted to the center of the axle tube.
Russ
Old 05-02-2012, 09:57 AM   #5
Trailer: U Hall VT
Smile
This should help
Roger Kimble is offline   Reply With Quote
axle
New axle and wheel size for Bigfoot 17? pindraak Towing, Hitching, Axles and Running Gear 19 09-05-2012 08:15 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
What size hubs do I need for a stock axle? Brian Scott Towing, Hitching, Axles and Running Gear 2 06-03-2008 12:35 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
What size hubs do I need for a stock axle? Brian Scott Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
» Trailer Showcase
Lupita
Shelley D
Beastie
BobB
